Looking for a drag link for my 2414 tractor
4 replies to this topic
#1 msta999 OFFLINE
msta999
  • 3 Thanks
  • 17 posts
Posted February 28, 2017 - 11:09 AM
mine is bent, anyone know where I can get one?
Thanks
#2 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted February 28, 2017 - 12:02 PM
Try Tractor Supply or other Farm & Home stores in your area.  Otherwise try eBay.
#3 MNGB ONLINE
MNGB
  • 1,713 Thanks
  • 1,221 posts
Posted February 28, 2017 - 12:56 PM
Thanks
Hi msta999, you have to be a little more specific can you post a picture of yours? They are all bent to some degree to work on the tractors, for a used replacement e bay maybe your best place or maybe your could be straightened as needed.
#4 msta999 OFFLINE
msta999
  • 3 Thanks
  • 17 posts
Posted February 28, 2017 - 06:03 PM
I'll take a pic tonight, it rubs on the bracket for the bucket and turns sharper to one direction than the other.
#5 classic ONLINE
classic
  • 4,818 Thanks
  • 2,126 posts
Posted February 28, 2017 - 11:01 PM
There are a few different types of steering stop pins. Some stop when they contact the front axle, and some stop on the tie rod ends. Make sure that they are in order. A loose tierod end can cause over travel along with bent stop pins. The Pittman arm on the steering box can be removed and installed in different positions to equalize how far left and right the front wheels turn. You should be able to turn all the way left and all the way right and have the stop pins make contact without bundling up the steering box. Is this something that has just started happening? You may be able to just bend your existing link and retime your steering. Pics would really help us out with this problem.
  • Alc and MNGB have said thanks
