1980 Sears LT10
8 replies to this topic
#1 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 27, 2017 - 06:41 PM
Another one of my finds. I paid just $20 bucks for this thing. I bought poured gas in it, and it ran great. Shredded a belt within a day of heavy use cutting atv trails. I put a new belt on it, and it ran great until this fall, when it started running at max throttle all the time, even on slow throttle. The cable works, I'm thinking the carb needs to be rebuilt. I looked inside the carb, and the choke, throttle, all seem to work just fine. It just revs up really high. I feel like it will explode. For the price, it will be worth getting going again this spring. I can't even buy a push mower around here for $20.
Edited by Y2K GTP, February 27, 2017 - 06:42 PM.
  • backwoods and boyscout862 have said thanks
#2 secondtry OFFLINE
secondtry
  • 1,681 Thanks
  • 1,284 posts
Posted February 27, 2017 - 07:04 PM
Check the manuals section, It might tell you how to fix it before it scatters. Don
  • Y2K GTP said thank you
#3 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
I will look into before I use it again.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted February 27, 2017 - 08:01 PM
Sounds like one of two things to me: you are running lean from a blockage or you have a governor problem.
  • boyscout862 and Y2K GTP have said thanks
#5 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 27, 2017 - 08:06 PM
I will pull the carb apart this spring, and clean it out, and see what happens.
#6 glgrumpy OFFLINE
  • 8,563 Thanks
  • 7,881 posts
Posted February 27, 2017 - 08:12 PM
I would bet governor problem, maybe just a spring or linkage wore off and fell off?  OR, kinda weird, but have seen throttle plates bend or break off the shafts and whole shaft and assmebly is jambed into wide open stance. Engine ate screws?  or hopefully just sheared off and still in there.  Just a thought.
#7 KennyP ONLINE
  • 37,487 Thanks
  • 45,503 posts
Posted February 28, 2017 - 05:49 AM
What are the 2 .html's? I tried to open them and got nothing.
I suspect the governor also. Good looking LT though.
#8 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 28, 2017 - 09:16 AM
Those 2 HTMLs should be manuals, but I guess the link doesn't work.
#9 KennyP ONLINE
  • 37,487 Thanks
  • 45,503 posts
Posted February 28, 2017 - 09:21 AM
PDF is the best way to have them. I might be able to help convert them.
