what's it worth ?
5 replies to this topic
#1 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted February 26, 2017 - 06:29 PM
Found this online for $300 with Deck and Snowblower hydraulic lift and PTO, Same as mine except blue and Hydro maybe?? anyhow what should i offer he thinks the motor is Seized.
Edited by Montgomeryluv15, February 26, 2017 - 06:31 PM.
#2 chieffan ONLINE
  • 10,124 Thanks
  • 6,630 posts
Posted February 26, 2017 - 07:16 PM
$300 running.  Dead - $75- $100 max.  But that is this area and my opinion.  Not a Monkey fan - to hard to find parts.
  • Gtractor, hamman, boyscout862 and 3 others have said thanks
#3 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,315 Thanks
  • 4,949 posts
Posted February 26, 2017 - 07:46 PM
I think Chieffan is spot on
  • hamman and Montgomeryluv15 have said thanks
#4 EricFromPa ONLINE
EricFromPa
  • 3,654 Thanks
  • 3,112 posts
Posted February 26, 2017 - 07:47 PM
Wouldn't offer much more than $100 if it was ran for long with the heat shield missing on the left head.
Not sure but that could be an aluminum bore engine.My MW 16 twin was the same Blue/white with electric pto and was an aluminum bore block.It smoked bad because it had some pretty nasty grooves cut into the aluminum bore and the rings were about shot.Still ran ok but smoked alot and had alot of blow-by vapor coming out of both breathers.
Eventually I got a good deal on a Craftsman GTV18 Varidrive with a blown transaxle and swapped the engine in the monkey wards.She was a beast but sadly the deck was to rough to save.Rusted and cracked from the spindle the whole way out across the chute.Couldn't find another deck shell so I sold it to someone that had a deck,plow and tiller from a non running Wards.He still has it and still uses it.
Edited by EricFromPa, February 26, 2017 - 07:47 PM.
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted February 26, 2017 - 11:01 PM
  • Gtractor, Montgomeryluv15 and Bill 76 have said thanks
#6 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted February 28, 2017 - 01:15 PM
Thanks everyone i left him a Ph message wish me luck on that Engine. Im probably going to buy it anyhow and if the engine has to be rebuilt so be it! other wise i was thinking of a Cheap Chinese Diesel repower! has anyone done that yet on a Monkey
