Engine Stand Adaptor To Hold Small Gas Engines
20 replies to this topic
#16 KennyP ONLINE
  • 34,242 Thanks
  • 43,363 posts
Posted March 01, 2017 - 03:39 PM
I've got one of those stands! Maybe time to get it out and use!
  • 29 Chev said thank you
#17 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 6,956 Thanks
  • 2,237 posts
Posted April 17, 2017 - 02:05 PM
Found out during the process of taking the engine apart that the paint on the tray was getting scratched a bit from setting tools and parts on it so I used a piece of black vinyl material I had and made a liner to set on top of the tray.  I sewed a binding on the edges (gave me an excuse to test out my home made swing away binder tool I made for the sewing machine) to keep the edges from fraying and then I set the vinyl in place on the tray - thought I would share a few pictures.
  • KennyP and dtsh have said thanks
#18 KennyP ONLINE
  • 34,242 Thanks
  • 43,363 posts
Posted April 17, 2017 - 06:51 PM
Any excuse will work! Nice job!
#19 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 6,956 Thanks
  • 2,237 posts
Posted May 01, 2017 - 05:34 PM
It was a wet day today so I decided to modify the two arms so that the cross bars could be mounted closer to the head.  Removed the arms and welded two pieces of 1/8" x 1-1/2" flat steel to the arm at the head end and drilled two 5/16" holes 1/2" from the end.  Then I cut the two outer rails and added a piece to extend them towards the head end and also added a support piece in the centre to bolt the rail to the arm.  A quick splash of paint and the engine stand was back together - now the cross bars can be mounted much closer to the head and post of the engine stand so the engine is not so close to the front of the stand.  Will have to try it out when I get the Wisconsin back from the machine shop.
  • KennyP, CRFarnsworth and Mark 149 J. have said thanks
#20 lrhredjb OFFLINE
lrhredjb
  • 465 Thanks
  • 419 posts
Posted May 01, 2017 - 06:33 PM
Nice job!
#21 KennyP ONLINE
  • 34,242 Thanks
  • 43,363 posts
Posted May 02, 2017 - 07:22 AM
That should work!
