My Redneck Vertical Table for a Horizontal Band Saw
28 replies to this topic
#16 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 7,105 Thanks
  • 2,320 posts
Posted February 25, 2017 - 07:26 PM
I've decided to opt out of the countersunk fasteners. That top plate is only 0.1" thick and would be hard to put those in. I'll drill holes thru and make some studs sticking down. I'll weld them in and grind the area smooth. Should work okay.
Are you going to make a stud holder to hold the studs while welding it or do you have nerves of steel?
#17 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted February 25, 2017 - 07:54 PM
He has nerves of steel!
  • KennyP and 29 Chev have said thanks
#18 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted February 26, 2017 - 06:18 AM
No stud holder!
Ubetcha!
Really, I'm going to thread the 0.1" and screw it in leaving it just shy of the top! That should hold it for welding.
  • SupplySergeant, 29 Chev and Mark 149 J. have said thanks
#19 Jazz OFFLINE
Jazz
  • 1,976 Thanks
  • 1,250 posts
Posted February 26, 2017 - 09:37 AM
No tilt! Just a straight cut for smaller stuff.
Tilting is todays project? It would be handy just a matter of deciding how to go about it.
I have similar saw. I made a table for my metal cutting saw and learned later many of these saws came with a table but as with many used items things get lost.
Edited by Jazz, February 26, 2017 - 09:44 AM.
  • KennyP and Mark 149 J. have said thanks
#20 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted February 26, 2017 - 09:56 AM
It gets real hard making it tilt, I'd end up with a huge mass of metal to make that work. The newer model table attaches different from how these old saws are made.
Your's looks simple. Did you take the side rollers off under there?
#21 Jazz OFFLINE
Jazz
  • 1,976 Thanks
  • 1,250 posts
Posted February 26, 2017 - 10:52 AM
The rollers are directly under table top. These machines are still the nicest tool for clean dust free cuts of metal. Slices through 1/2" steel place easily with course blade installed. Maybe someone has a simple,, very simple solution to creating a tilting table. I have yet to come up with anything
Edited by Jazz, February 26, 2017 - 01:00 PM.
#22 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted February 26, 2017 - 04:11 PM
Came up with a different idea! I know, I'm thinking again. Anyway, I remembered I had this piece laying about.
It won't work as the thick part is only 3/16" and I need 1/4" to match the plate under the table.
I found some strap to use. Here's how I put a 'bow' in the end.
The table works, used it to cut the pieces.
Then I decided this strap was too thick. It would make it hard to 'clip' the table on. I found some thinner metal to replace this, but the race was starting, so it'll wait until tomorrow.
  • 29 Chev and Mark 149 J. have said thanks
#23 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted February 27, 2017 - 02:48 PM
Made up the clips this morning. Got them installed.
Works as it should!
Best part is I can slip the table off and still cut horizontally.
Here's another thing I made up for cutting multiple parts the same length.
All done with this!
  • EricR, TomLGT195, SupplySergeant and 1 other said thanks
#24 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted February 28, 2017 - 08:31 AM
Great work, Kenny. Looks at least as solid as the factory option, and probably better than the ones in stores today!
#25 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,682 Thanks
  • 998 posts
Posted March 02, 2017 - 12:15 AM
Nice!
I like how you made it easy to remove.  How easy is it to slide back on and off?
Edited by Mark 149 J., March 02, 2017 - 12:15 AM.
#26 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted March 02, 2017 - 05:42 AM
Not bad! I tap it on with a small hammer or piece of iron, but it's light taps.
  • Mark 149 J. said thank you
#27 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,682 Thanks
  • 998 posts
Posted March 02, 2017 - 10:38 AM
Sounds perfect.
#28 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted March 02, 2017 - 11:19 AM
Sounds perfect.
Tight enough it doesn't move when cutting.
#29 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 7,105 Thanks
  • 2,320 posts
Posted March 02, 2017 - 08:27 PM
It must have nerves of steel as well.
