Wanted
Zenith carburetor for Wisconsin TR10D
11 replies to this topic
#1 SgtMoonracer ONLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted February 23, 2017 - 09:48 PM
The float on my Zenith L80 carb broke in half (again). The carb is on a TR10D engine, and actually should be an L63 if I'm researching this correctly. I either need another float for the L80, (which seem scarce as hen's teeth), or a working L63 carb if anybody has one lying around.
Thanks in advance!
#2 Bolens 1000 OFFLINE
  • 15,291 Thanks
  • 18,235 posts
Posted February 24, 2017 - 08:47 AM
I'm out of New and Used floats, I can get new carbs but probably alot more than your comfortable spending
  • SgtMoonracer said thank you
#3 chieffan OFFLINE
  • 10,903 Thanks
  • 6,926 posts
Posted February 24, 2017 - 09:55 AM
Is that a brass float?  If it is get the pencil soldering iron out and have at it.  Been thousands of floats repaired that way.  If it's plastic,, might have to do some hunting to find an adhesive that will stick to it and stay.
#4 Bolens 1000 OFFLINE
  • 15,291 Thanks
  • 18,235 posts
Posted February 24, 2017 - 10:15 AM
The floats on the L80 series were a composite plastic like material
#5 SgtMoonracer ONLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted February 24, 2017 - 10:30 AM
I checked your site first, and saw you were out. There are a couple on ebay, but I'd rather buy from somebody here if someone has one lying around.
Chieffan, I thought about trying to "glue" it, but I'm not sure if anything will hold immersed in gasoline. The break is fairly clean.
  • Bolens 1000 said thank you
#6 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted February 24, 2017 - 11:34 AM
I should have a spare carb, I just need to find it. I'll take a look and let you know.
#7 Bolens 1000 OFFLINE
  • 15,291 Thanks
  • 18,235 posts
Posted February 24, 2017 - 11:36 AM
Looking at my inventory I do have one new one I could sell you, Inventory was off and thought I only had one which I was saving to reproduce
#8 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted February 24, 2017 - 12:49 PM
I have a spare used carb I'd sell.
#9 rjmartinny OFFLINE
rjmartinny
  • 10 Thanks
  • 15 posts
Posted February 24, 2017 - 07:07 PM
Here is a guy that has floats for you L-63 carb, used carbs as well,   mrdadsr@aol.com  give him a try what do you have lose
#10 Bolens 1000 OFFLINE
  • 15,291 Thanks
  • 18,235 posts
Posted February 24, 2017 - 07:49 PM
He needs a float for an L80
Are you related to a "Susan Made"
#11 SgtMoonracer ONLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted February 25, 2017 - 05:09 AM
Sent you a PM.
#12 rjmartinny OFFLINE
rjmartinny
  • 10 Thanks
  • 15 posts
Posted February 25, 2017 - 10:43 AM
I believe he has L-80 float as well and I know he has carbs and parts for Zenith & Walboro carbs on the S-10, S-12 & S-14 engines as well.  No
