Does anyone know were i can get rear axle seals for a sears suburan 10 h.p.
9 replies to this topic
#1 johndeereandy OFFLINE
johndeereandy
  • 6 posts
Posted June 07, 2011 - 09:36 PM
i just got a sears suburan 10 h.p. garden tractor and i saw that the seal was broke. i search all over and i can't find nothing
please help if you can.
johndeereandy,
thank you
#2 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 07, 2011 - 09:38 PM
I bough a couple the other day from auto parts store. Can you get the model number off the tractor???
#3 johndeereandy OFFLINE
johndeereandy
  • 6 posts
Posted June 08, 2011 - 05:40 AM
no becuase the model number has wear off and can,t see it that well. you can see part of it,but the end of it is wear off.
#4 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted June 08, 2011 - 08:26 AM
If you can get the old seal out in one piece and without mangling it too much you might be able to take it in to your local auto parts store and they might be able to match it up for you.
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 08, 2011 - 08:45 AM
Are you near a larger Metropolitan area? I live about 35 miles from Des Moines, and can't tell you how many times in my youth, my dad gave me some ugly beat up unidentifiable bearing , grease seal or Belt and sent me to Des Moines to "Standard Bearing" Dad did landscape and grading work and was always finding some obsolete piece of equipment to fix and use.
They would get out their Calipers and books and never failed to come up with the part that matched.
So if you have a bearing supply house(Most Cities will have one) in the area they can probably find a match even without a part number.
I had almost forgot them, but Sunday Night my brother was telling me they were the cheapest place to get a belt for one of my mowers.
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted August 29, 2011 - 11:17 PM
This may already be OBE (overcome by events), but I posted a Timken seal reference under the "manuals" section. It gives cross references to other seals, as well as dimensional information... hope this helps.
Utah Smitty
#7 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted August 30, 2011 - 05:09 AM
That could be of great help. Thanks, Utah Smitty.
#8 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted August 30, 2011 - 01:47 PM
Use a dial caliper to check the tube the seal fits in to get the outer diameter, then measure the sealing face of the shaft. Then measure the thickness of the seal. Armed with these measurements, a good seal supply will match you right up. Take what's left of the old seal with you too.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 30, 2011 - 05:17 PM
I'll 4th the notion, take the old one to any good bearing supplier and they can get you another seal. Theres really no such thing as a seal for one specific brand of tractor. All kinds of seals have been made over the yrs that just fit shafts of whatever size, most of them are still being used, just not on a Sears tractor.
#10 mjodrey OFFLINE
  • 2,355 Thanks
Posted August 30, 2011 - 06:22 PM
That's the way I do it sometimes.
