A Tool I Made
14 replies to this topic
#1 KennyP ONLINE
  • 52590 Thanks
  • 53119 posts
Posted February 22, 2017 - 03:57 PM
Wanted to share this with you folks. Sometimes we need to weld a round shaft or something back together, but need it as true as we can get it. Introducing the new and improved Vee Tool. Soon the be sold be Ronco! LOL
With this, you can clamp two part in and tack in at least 3 places to keep it as true as we can get it.
  • Bolens 1000, Gtractor, MH81 and 25 others have said thanks
#2 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted February 22, 2017 - 04:36 PM
Or
With this, you can clamp two part in and tack in at least 3 places to keep it as true as we can get it while you eat LEAN BURGERS! LOL
Or, just grab it N spin it!
If it needs to be that straight,  a lathe is what u need, not a welding  jig.
Definitely a good idea though; )
Edited by stiemmy, February 22, 2017 - 04:39 PM.
#3 chieffan OFFLINE
  • 16413 Thanks
  • 9041 posts
Posted February 22, 2017 - 04:44 PM
Never thought of cutting the notch out of the V.  Have used a piece on angle iron many times.  Your tool is better and a lot cheaper than a lathe that only gets used 4 times a year.
  • KennyP, propane1 and Mark 149 J. have said thanks
#4 KennyP ONLINE
  • 52590 Thanks
  • 53119 posts
Posted February 22, 2017 - 04:47 PM
Or
This is for those of us without a lathe!
If you have a longer piece, use a longer angle iron to keep it right.
  • boyscout862, stiemmy and Mark 149 J. have said thanks
#5 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted February 22, 2017 - 04:55 PM
As I stated,  great idea!!!!!!!!!
#6 KennyP ONLINE
  • 52590 Thanks
  • 53119 posts
Posted February 22, 2017 - 05:01 PM
We had a member with a broken drive shaft. This would help him weld it back together!
  • stiemmy and propane1 have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted February 22, 2017 - 06:01 PM
  I have something similar about 4' long I use to splice pipe and square tube. Bed frame angle works really good because it doesn't bend easily.
                                           Mike
  • KennyP, HANKG and propane1 have said thanks
#8 propane1 ONLINE
propane1
  • 13511 Thanks
  • 5961 posts
Posted February 22, 2017 - 06:14 PM
The more I think about , the better it gets. Great idea, Kenny. I have run into to some thing like a pipe or shaft that I had a hard time getting it straight to weld. Thanks.
I don't have a lathe.
Noel
Edited by propane1, February 22, 2017 - 06:15 PM.
#9 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 18891 Thanks
  • 11847 posts
Posted February 22, 2017 - 06:51 PM
I don't have a welder, but I know who to call now.
#10 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 4100 Thanks
  • 2147 posts
Posted February 22, 2017 - 06:56 PM
Great, simple, cheap, perfect!!!
#11 jms180 OFFLINE
jms180
  • 2637 Thanks
  • 2152 posts
Posted February 22, 2017 - 07:16 PM
Nice piece of work Kenny
#12 SimplyRad OFFLINE
SimplyRad
  • 2011 Thanks
  • 1327 posts
Posted February 23, 2017 - 09:05 AM
Good idea Kenny. I have used angle iron before but had access to a lathe back then but not now. I have a 3' piece of stainless I could do that to.
#13 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted February 23, 2017 - 10:55 AM
Yeah man.
#14 secondtry OFFLINE
secondtry
  • 4862 Thanks
  • 2858 posts
Posted February 23, 2017 - 01:15 PM
That strategy works very well. If you use a much larger angle and go slow you can  make the hole large enough to to weld it out completely while clamped and allow it to cool in place. You have to go slow so you don't over heat and warp the angle. Don
#15 secondtry OFFLINE
secondtry
  • 4862 Thanks
  • 2858 posts
Posted February 23, 2017 - 02:03 PM
  I own 5 lathes of differing size, 12" Atlas Craftsman being the largest. I have to admit ignorance here, I have no idea how one would hold both pieces of a broken shaft in a lathe in such a way to insure they were straight and concentric. Since little more than 3/4 inch can pass through the head stalk length and diameter can be severely limited. With the angle getting a larger size is not likely to break the bank. ???? Don
  • KennyP and LilysDad have said thanks
