Made me a cultivator
29 replies to this topic
#1 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 08:48 PM
Needed a cultivator to work the garden up better. so I made one.IMG_0112.jpg
#2 wvbuzzmaster ONLINE
  • 4,662 Thanks
  • 7,408 posts
Posted June 07, 2011 - 08:57 PM
Great fab work, it appears to do quite a nice job in the garden.
#3 Aussiedog OFFLINE
Aussiedog
  • 56 Thanks
  • 55 posts
Posted June 07, 2011 - 09:06 PM
Great job...
I see the mountains in the background. I drove through your area years ago. Lewiston is a beautiful place.
#4 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted June 07, 2011 - 09:12 PM
Looks simple and efficient. Nice job!
#5 Alc ONLINE
  • 5,996 Thanks
  • 6,922 posts
Posted June 07, 2011 - 09:18 PM
Nice job , I like the weight bracket you added too.
#6 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 10:38 PM
Thanks all, It was fun (as always) to make this. I added the weight trays as I felt it was not digging in deep enough. the sleeve hitch worked great. tho a little difficult to raise it with all the wt on in. the teetha are 24 inches from the back plate, thinking of shortening the arm by 3" might make it slightly easier to raise. and the drive belts were slipping so need to adjust them
#7 MH81 ONLINE
  • 28,933 Thanks
  • 29,284 posts
Posted June 07, 2011 - 11:28 PM
Nice job. It looks to work well.
My son is 12 and had trouble lifting the plow. I put a spring from the bottom of the lift handle towards the front of the tractor to help a little. Also, there are 3 holes down there, one of them may give you better leverage, while not lifting the implement quite so much.
Edited by MH81, June 08, 2011 - 06:22 AM.
  • Justpics said thank you
#8 daytime dave OFFLINE
  • 4,553 Thanks
  • 6,382 posts
Posted June 07, 2011 - 11:32 PM
Looks great. Nice job
#9 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 11:39 PM
My son is 12 and had trouble lifting the plow. I put a spring from the bottom of the lift handle towards the fro of the tractor to help a little. Also, there are 3 holes down there, one of them may give you better leverage, while not lifting the implement quite so much.
How big of a spring. I like the idea of it.
#10 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 11:41 PM
Great job...
I moved here a little over a year ago from the Portland area. but was raised in north east Oregon
#11 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 11:42 PM
Thanks, appreciate it
#12 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 07, 2011 - 11:43 PM
It surprised me how good it did work, dug right in, the tractor would only pull it in 1st. started slipping in other gears, need to adjust.
#13 KennyP ONLINE
  • 32,269 Thanks
  • 42,051 posts
Posted June 08, 2011 - 03:53 AM
I like your cultivator. Looks like it should do the job. Some type of spring assist on your lift would be a plus.
#14 mjodrey OFFLINE
Posted June 08, 2011 - 04:21 AM
Nice job.
#15 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted June 08, 2011 - 05:19 AM
Wow, that looks better than some store bought ones. Very nice. Did you buy the sleeve hitch attach part? If so where?
