David Bradley Cordwood Saw Trailer
15 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted February 21, 2017 - 07:16 PM
I found this saw recently and have been messing with it for a couple days on and off ,
I was just out playing around and have taken all of the stuff off that doesn't belong .
I was lining it up to my Suburban just to see .
It will not be hard at all to make an adapter .
I had an old belt , it is the perfect length. It allows the disengage arm to operate.  (Will get a new one.)
The plan is to attach an axle to the front base which will have easy removing wheels . Not those plastic mower ones but something vintage and classic.
Then I will put a hitch pin to the back adapter .
Instant Cordwood saw 'trailer' for a David Bradley Suburban !
Pull it out to where you need it . Wheel it around front , Hook it on ,remove wheels ,  add belt and you are in business .
All of this will be done without compromising the original piece in any way.
Edited by MGP59DB, February 21, 2017 - 07:19 PM.
  • Alc, KennyP, Cvans and 7 others have said thanks
#2 Alc ONLINE
  • 7,233 Thanks
  • 7,583 posts
Posted February 21, 2017 - 07:23 PM
Nice ! If you put casters on you could mount it to the front like a mower
  • boyscout862, Leonard VanCamp, MGP59DB and 1 other said thanks
#3 jabelman OFFLINE
jabelman
  • 2,249 Thanks
  • 1,609 posts
Posted February 21, 2017 - 07:29 PM
wow! that looks dangerous make sure that suburban doesn't pop into drive
  • Alc, boyscout862 and MGP59DB have said thanks
#4 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted February 21, 2017 - 07:35 PM
It will work , but probably won't be used , much , this tractor doesn't pop into gear , you must push and hold as well as have the belt speed adjuster engaged . But yes , and I will always have wood blocks on tires too .
  • Alc, boyscout862 and propane1 have said thanks
#5 propane1 ONLINE
propane1
  • 9,470 Thanks
  • 4,397 posts
Posted February 21, 2017 - 08:02 PM
That's neat. And be able to use it if wanted. I like it. Hopefully we can see a video of it cutting some wood.
Noel
  • MGP59DB said thank you
#6 KennyP ONLINE
  • 40,934 Thanks
  • 47,125 posts
Posted February 22, 2017 - 06:54 AM
Looks like that will work.
#7 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted February 22, 2017 - 02:43 PM
Noel
It won't take too long to get this together , I have to figure out a day to take it to my Uncles shop and get it blasted , soon as the weather is good .
I have a cultivator to do also , so it is in the works .
I will get some video , it will work ! And will look good doing it :smilewink:
I am still pretty excited by this find . I haven't ever seen one before (cept in pictures)and now I have one.
  • KennyP and propane1 have said thanks
#8 KennyP ONLINE
  • 40,934 Thanks
  • 47,125 posts
Posted February 22, 2017 - 04:43 PM
Awesome find! Have fun with it!
#9 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted February 22, 2017 - 06:20 PM
I found some wheels I really think will look good on this.
Steel inner , solid 8"  , I think these have a classy look to them ,they match somewhat to the DB , a coat of paint. Or leave em' red.
Vintage metal wheels maybe later , but crap , I can't pay more for wheels than the saw .
People are asking so much for good old wheels.
  • Alc, KennyP and propane1 have said thanks
#10 jabelman OFFLINE
jabelman
  • 2,249 Thanks
  • 1,609 posts
Posted February 22, 2017 - 07:12 PM
I have a pair of those wheels pm if interested
Edited by jabelman, February 22, 2017 - 07:21 PM.
#11 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted March 06, 2017 - 04:41 PM
Why tow it. Just adapt it onto an old mule drive add a hinge point and just,  Lift it , Brace it  and drive it to the job. No need for wheels at all.
#12 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted March 06, 2017 - 06:44 PM
I think the design of the saw lends itself to doing this . Plus I don't have an old mule drive laying around I want to cut up.
This set up will not change or destroy anything and will be fun . IMO
#13 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted April 12, 2017 - 06:22 PM
I finally was able to get back to this  project today . Went up to my Uncles shop and started doing the retrofitting.
Got the 'wheel'attachments built and set up .
One of the guard welds was broken so that was repaired.
The saw mounting face was slightly tweeked , so we had to pull the shaft out and check it. , Seems the shaft is straight , but the plate the blade bolts to was bent causing the blade to wobble .040 is all , but that translated to a lot of wobble out at the teeth of the blade ,
So we put it in the lathe and trued up the face. Should be fine now.
Then we started to figure out the mounting pieces that need to be made.
Couldn't find any of the right stock needed at the shop so I will have to go buy some pieces to use .
We refurbished this DB last summer (mostly my Uncle) He had the fun and I bought the tractor from him . Nice Job !! It is dusty from sitting over the winter and needs to be cleaned off and touched up in spots .
What a beauty !!
Edited by MGP59DB, April 12, 2017 - 06:33 PM.
#14 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted September 05, 2017 - 06:05 PM
It has been a pretty busy summer , working on alot of different  projects , but this is almost done  :D
It is fixed where it needed work , it has been blasted and primed , the modifications are made . all it needs is the final paint and assembly !
If it wasn't raining a bit I would have done it today.
#15 Alc ONLINE
  • 7,233 Thanks
  • 7,583 posts
Posted September 06, 2017 - 05:47 AM
Looking forward to seeing it all painted up and running . I used the DB w/cordwood saw last week to cut up some kindling .
