Briggs ID
4 replies to this topic
#1 Dave S OFFLINE
Dave S
  • 19 Thanks
  • 28 posts
Posted February 21, 2017 - 02:18 PM
I have a Briggs and Stratton horizontal shaft that has been painted several times. Only visible markings is I C and M 680905. Can someone identify this with this information? Thanks
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted February 21, 2017 - 03:47 PM
You probably need to provide more info than that to get an ID.
Any idea of the approximate age of the engine?
Is it possibly the original starter housing, or has it been replaced?
Can you post pictures of the starter housing (flywheel shroud) from all angles?
If the B&S numbers are covered over with paint, sometimes by removing the starter housing, the stamping is visible on the inside.  ...It may not be readable, but you may then be able to know where to remove the paint.
#3 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted February 21, 2017 - 05:21 PM
I have not tried this but could you possibly read the inside numbers with a mirror
#4 jimmy G ONLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted February 21, 2017 - 05:48 PM
their not stamped hard enough,should be on the exhaust side of blower housing where it's flat
  • Bruce Dorsi said thank you
#5 MiCarl ONLINE
MiCarl
  • 1,913 Thanks
  • 1,020 posts
Posted February 21, 2017 - 06:10 PM
If it's got a spray can paint job a rag with a little lacquer thinner and gentle scrubbing might remove the new paint.
