MF 16 diesel repower
15 replies to this topic
#1 Thoover OFFLINE
Thoover
  • 10 Thanks
  • 5 posts
Posted February 17, 2017 - 06:41 PM
I'm looking to buy a Kubota z400 2 cylinder diesel to put in a Massey Ferguson 16. Does anyone have dimensions of this engine with the radiator to see if it will fit?
  • pryan05 said thank you
#2 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,011 posts
Posted February 17, 2017 - 08:05 PM
Hi, new guy!  Couple guys on here working on similar re-do, check the Massey Forums.  Think they have little bigger engines. Believe one is lengthening the frame? How about some pix with Your story!
#3 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted February 18, 2017 - 06:06 AM
:wave: Welcome to the forum! This sounds interesting. Pic uploading help is in the link in my signature.
#4 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted February 18, 2017 - 08:29 AM
Welcome to GTtalk!
And that sounds like an interesting project.
  • polarisdiesel and pryan05 have said thanks
#5 Thoover OFFLINE
Thoover
  • 10 Thanks
  • 5 posts
Posted April 19, 2017 - 04:10 PM
Not done yet but heres a couple pics for an update. Lots of modifications but it looks like everything is going to work.
  • coldone, shorty, Cat385B and 3 others have said thanks
#6 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted April 19, 2017 - 04:25 PM
That is looking really good!  The MF14 and 16 are my favorite garden tractors and you just made the that one awesome.  You'll be very happy with that little diesel.  I put a d722 in a Ford lgt 165 and so far so good.  You got to love the noise they make.  Thank you for the posts.
Edited by pryan05, April 19, 2017 - 04:43 PM.
#7 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted April 19, 2017 - 04:44 PM
I didn't see a fuel tank...  What are your plans for it?
#8 Thoover OFFLINE
Thoover
  • 10 Thanks
  • 5 posts
Posted April 19, 2017 - 06:17 PM
Fuel tank is the last thing to make. I'd like to hide it under the seat but I'm afraid it will have to be too small of a tank. There was absolutely no fitting the engine in there with the original tank.
#9 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted April 19, 2017 - 06:25 PM
Here is what I did with my LGT I got the idea from skyryder2.20170419_185208.jpg
It works really good it hold about three gallons.
  • Mark 149 J. said thank you
#10 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,011 posts
Posted April 19, 2017 - 06:40 PM
Wow! That is SO clean all over!  Looks like fitting nice! Good job!
#11 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted April 19, 2017 - 07:19 PM
Beautiful workmanship. Think your really going to like your tractor when it is done.
#12 Thoover OFFLINE
Thoover
  • 10 Thanks
  • 5 posts
Posted May 15, 2017 - 04:35 PM
Well everything is done and hooked up but the engine absolutely will not start! Filters are changed, fuel lines have been bled over and over inlcuding up to injectors. Even had injectors out and turned to see the spray pattern and it was good. Glow plugs could be seen working while injectors were out. It smokes like crazy cranking over and it's spinning plenty fast with a charger. It ran before starting the swap and I haven't messed with anything internal like timing. Any ideas?
#13 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted May 15, 2017 - 07:46 PM
Didn't happen to leave a rag in the intake did you?
#14 Thoover OFFLINE
Thoover
  • 10 Thanks
  • 5 posts
Posted May 15, 2017 - 08:11 PM
No but that crossed my mind too. I took the whole intake off to make sure.
  • Cvans said thank you
#15 MH81 OFFLINE
  • 29,978 Thanks
Posted May 15, 2017 - 09:29 PM
Just to play devils advocate, any chance the shaft and hydro are lugging it down just enough to not want to start?
