Crazy idea or not
7 replies to this topic
#1 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted February 16, 2017 - 07:28 PM
I have a real nice craftsman 8 hp gt tiller. It is a sleeve hitch setup.what I am thinking on doing is making an adapter to 3 point.seems pretty simple to make an adapter to fit into hitch on tiller. Just make a drawbar sorta thing like the drawbar I made for my 3 point, so it is held with the pin on hitch,weld a piece for the center link to hook to.is the pin diameter all the same on 3 Points? I'm going to fit it up to my suburban 12,it has 5/8 pin holes. My thinking is when I sell it if everything works right, it won't matter what hitch you have on the tractor,might be easier to sell
Edited by Xrperry, February 16, 2017 - 07:44 PM.
#2 MiCarl ONLINE
MiCarl
  • 2659 Thanks
  • 1321 posts
Posted February 16, 2017 - 07:40 PM
Cat 0 top link and lift pins are all 5/8.
  • Xrperry said thank you
#3 tater195 OFFLINE
tater195
  • 2347 Thanks
  • 1492 posts
Posted February 16, 2017 - 07:57 PM
How wide? If it doesnt cover the width of the tractor, you will pack it back down on the next pass
#4 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted February 16, 2017 - 09:07 PM
I think it's a 36 inch not sure,I don't plan on using it,I was just going to use the suburban for a test tractor. Good point tater.i thought it would be a good selling point,for it to fit a sleeve hitch or a 3 point
#5 DukeWicked OFFLINE
DukeWicked
  • 16 Thanks
  • 17 posts
Posted February 17, 2017 - 12:23 AM
So does that tiller cover the width of the tractor? If so how much you want for just the tiller? (I seen your ad on the Suburban)
#6 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted February 17, 2017 - 12:51 AM
I'm not sure what the tiller is worth yet. It was used very little.
#7 DukeWicked OFFLINE
DukeWicked
  • 16 Thanks
  • 17 posts
Posted February 17, 2017 - 02:04 AM
Well PM me when you do. Got a ST16 that it would be good on.
#8 Alc ONLINE
  • 9081 Thanks
  • 8325 posts
Posted February 17, 2017 - 06:29 AM
That's a good point !  Maybe if it's narrower then the tractor you could offset the till to one side . The factory tiller on my Economy  Jim Dandy is like that . You just need to remember which side ( direction )  to work from
