GT18 axle separation issue
gt-18
8 replies to this topic
#1 Fryeburg500 OFFLINE
Fryeburg500
  • 2 posts
Posted February 15, 2017 - 11:11 AM
Good morning all. We're getting hammered up here in Maine with the white stuff and im in need of some help. After a long snowblowing session with my GT-18 tractor, I went to move forward from reverse slowly and there was a (Lack of perfect description) very light thud like a shear pin snapped or a keyway let go. That sort of thud. After that happened, the tractor would not move forward or back. I pulled the tractor into my garage and while doing so, the right rear tire and axle slid out of the tractor. I can only hope and pray that there's a shear pin or keyway that let loose, resulting in this failure. I'm also hoping and praying that someone on this forum can let me know what they think it is and / or how to fix it. In looking at the manual, the detail schematic of the rear axle does not show a keyway or shear pin. It only shows a "dowel pin" and a "lock pin". Any advice or help would be huge at this point. Thank you.
#2 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted February 15, 2017 - 11:26 AM
The axles are held in by the tapped roller bearing.
Your park lock cable may have broken. Allowing the park lock pin to engage the spur gear.
Sent from my SM-G920P using Tapatalk
#3 KennyP ONLINE
  • 34,234 Thanks
  • 43,350 posts
:wave: Welcome to the forum. That doesn't sound good! Someone should be along to help, may be a bit!
#4 Billy M OFFLINE
Billy M
  • 552 Thanks
  • 488 posts
Posted February 15, 2017 - 11:30 AM
Was the axle complete with the splines on the end, or did it break?  If it's complete, there is probably a groove at the inside end for a clip that may have broken.  I would want to disassemble and inspect as that's not a common occurrence. If it is just a clip failure, the repair is cheap on parts, but labor intensive.
#5 John Arsenault ONLINE
John Arsenault
  • 1,479 Thanks
  • 809 posts
Posted February 15, 2017 - 12:04 PM
Howdy neighbor I am from Rumford Maine. I am thinking you are going to get lucky and find its just a key way or clip. Once you find out whats wrong feel free to post here because I may have a part for you if needed. I have a few suburbans I bought for parts needed to fix mine and happen to have a complete transmission (i think they are the same as the suburbans). I have also had these transmissions apart and they are very easy  to work on some parts available at searspartsdirect (seals gaskets clips) so what ever it is I am sure it can be fixed.
#6 secondtry OFFLINE
secondtry
  • 1,128 Thanks
  • 926 posts
Posted February 15, 2017 - 12:17 PM
Pictures of the axle could help get more responses. Some times a visual is a real memory booster. Don
#7 John Arsenault ONLINE
John Arsenault
  • 1,479 Thanks
  • 809 posts
Posted February 15, 2017 - 12:47 PM
Oh my bad you got an ariens gt18 not a sears gt18 ......sorry I just noticed that
I think I have done too much snow removal myself. Just sitting inside today watching it fall drinking coffee trying to help....but ooooops
#8 chieffan ONLINE
  • 8,396 Thanks
  • 5,810 posts
Posted February 15, 2017 - 06:55 PM
Why is it they never break down in a warm shop.  Always has to be out in the cold when we really need them.
  • Wm McNett said thank you
#9 dodge trucker OFFLINE
dodge trucker
  • 1,884 Thanks
  • 2,496 posts
Posted May 29, 2017 - 08:47 PM
I see that OP hasnt been here in over 3 months, curious to see if this ever got resolved.  I happen to have a rear axle out of an S16H sitting here that was a very incomplete machine when it came to me, not worth making whole again..
Also tagged with one or more of these keywords: gt-18
