New here with a Squire 12
squire 12
34 replies to this topic
#16 KC9KAS ONLINE
KC9KAS
  • 5,390 Thanks
  • 4,693 posts
Posted February 15, 2017 - 05:26 PM
Your GT is what they called the "S" frame.
  • Y2K GTP said thank you
#17 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 16, 2017 - 02:36 PM
I took a video of me driving it around. Pretty nice tractor over all.
  • Alc and Mark 149 J. have said thanks
#18 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 16, 2017 - 02:37 PM
Fixed the broken hood latch, cleaned out the gas tank. I cleaned the connections on the relays.
#19 ACmowerguy OFFLINE
ACmowerguy
  • 428 Thanks
  • 372 posts
Posted February 19, 2017 - 01:26 AM
The engine is a 16hp Cast-Iron Briggs.
#20 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 04:17 PM
I was driving this tractor around today, and the drive shaft snapped into two pieces. I doubt getting a replacement is an option, but I'm thinking I could either get another piece of steel rod, and cut it to fit, or weld this one back together. Anyone here have any thoughts?
#21 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 04:33 PM
I believe it is part 'P' that broke. It is in two pieces right now. IT broke right under the battery.
Edited by Y2K GTP, February 19, 2017 - 04:34 PM.
#22 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted February 19, 2017 - 04:45 PM
The hard part about welding is keeping it straight. Got some pics of the carnage?
#23 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 05:18 PM
I know a professional welder. He should be able to get it nearly perfect again. I could do it, but I it would probably break again.
#24 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 05:20 PM
Taking it out will be easy since it will be in two pieces, but it looks like I may need to remove either the engine, or part of the gear box to get it in place again. Hmm...a free tractor is going to be a lot of work all of sudden. I am determined to save it since it was my grandfathers.
#25 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted February 19, 2017 - 05:51 PM
It looks to have been rubbing on the steering. May need to address that too. You need to get the overall length so it can be welded back correct.
#26 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 06:08 PM
I noticed it has been rubbing on the steering shaft for a long time. I wonder if I can slot the engine bolt holes and move it over to clear the steering shaft.  Maybe I will just take the entire tractor to my welder, and let him fix it. I hate to do that to him, as he is busy this time of year, but he might be able to fix it. Or I could I just remove the shaft and weld it myself and put back in, and see how long it lasts.
#27 secondtry OFFLINE
secondtry
  • 1,907 Thanks
  • 1,391 posts
Posted February 19, 2017 - 06:14 PM
Can't tell from the pictures, is that a solid shaft or tube. Don
#28 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 06:25 PM
It is a tube.
#29 Y2K GTP OFFLINE
Y2K GTP
  • 61 Thanks
  • 47 posts
Posted February 19, 2017 - 06:32 PM
I did some searching on the site, and came across this thread topic, from a member from Sweden, and he had a broken drive shaft on a Gilson tractor. Which I believe is about the same tractor. His broke in a different spot, but it looks like it is was able to be welded up again.
http://gardentractor...n-a-gilson-g10/
#30 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted February 19, 2017 - 07:13 PM
It can. You'll need a length (~12") of angle iron. Cut a slot out of the vee about 2" X .75". You'll need that to keep the two ends straight while welding. If you have a length of round stock the will fit inside, that can help. Clamp each end into the angle. Then tack weld in three place around so it will hopefully stay straight. You can loosen the clamps and spin the tube so you can tack three other places. Be sure to clamp it back first. If it's straight, you can finish welding.
