Ariens S14 3point sway chain mounts?
8 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted February 13, 2017 - 05:46 PM
Does anyone have a good picture of how the sway control chains mount on one of these tractors?
#2 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted February 13, 2017 - 09:03 PM
I thought I had one, must be on the pc that crashed. There is a tab that is on the same pin as the lift arm that the chain is welded to then runs over an adjuster on the other arm. I will try to get a pic this week.
  • adamjd200 said thank you
#3 Scrapr65 OFFLINE
Scrapr65
  • 22 Thanks
  • 24 posts
Posted February 16, 2017 - 10:08 AM
Im pretty sure they crisscross then mount in your lower arms where your pins go threw. Sorry i dont have a pic of it.They mount on the inside of the arms against the frame. I hope this helps. :thumbs:
#4 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted February 20, 2017 - 06:28 PM
Hope this helps.
#5 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted February 20, 2017 - 09:09 PM
Thanks, that helps a lot, I think I'm going to modify this and just use an eye bolt in place of the tab and turnbuckle.
  • shorty said thank you
#6 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted February 20, 2017 - 10:31 PM
I have one original chain and the other is home made.
#7 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted February 21, 2017 - 09:52 PM
I currently have 3' of chain with tabs welded to each end, I will cut two sway chains out of that, all my adjusters with be a eye bolt through the arm with a jam nut on each side of the arm, simple yet effective.
#8 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted February 22, 2017 - 04:43 PM
I keep thinking I want to build a right sway chain so I have a matching set. But what I got does the job and its not on a show piece.
#9 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted February 24, 2017 - 10:33 AM
Mine won't be 100% correct, but they will look good, this tractor will see a few shows.
  • KennyP and shorty have said thanks
