B12 differential help
4 replies to this topic
#1 goldstar OFFLINE
goldstar
  • 1 Thanks
  • 4 posts
Posted February 11, 2017 - 01:04 AM
  I have an A/C B12 differential problem. The outer ring gear is worn out. I was
wondering if there is a way to just lock the differential,or maybe someone knows
where i can buy one. This is the gear that is pinned onto the hub. Any help
would greatly appreciated.
  • chieffan said thank you
#2 stiemmy OFFLINE
stiemmy
  • 2,527 Thanks
  • 1,827 posts
Posted February 11, 2017 - 01:56 AM
A hot welder is what we used to usein the old Demo cars. Crude, but works. Never busted a rear, just other small parts
  • chieffan and goldstar have said thanks
#3 stiemmy OFFLINE
stiemmy
  • 2,527 Thanks
  • 1,827 posts
Posted February 11, 2017 - 01:58 AM
Key was heating it up before burning it it.
Now, the turning radius sucked, but it worked .
  • goldstar said thank you
#4 boyscout862 ONLINE
  • 11,838 Thanks
  • 8,680 posts
Posted February 11, 2017 - 02:15 AM
Welcome to GTT. You can replace or rebuild the rear. Check with our Sponsors for the parts. Look in our Manuals Section for the Manuals that you need. That transaxle was used on many AC and Simplicity tractors. There are of thousands around. Check your local scrap yard. I've bought nonrunning tractors of those models for $50 to use for parts. Good Luck, Rick
#5 petrj6 OFFLINE
petrj6
  • 4,080 Thanks
  • 2,369 posts
Posted February 11, 2017 - 07:08 AM
    I wouldnt lock it, thats just  gonna make it difficult to use.  Look around for parts or maybe even a donor tractor, the trouble you are gonna have is this is a fairly common problem on these tractors.  I have had to replace two or three over the years.
        Pete
  • Alc, boyscout862 and goldstar have said thanks
