got the hydro straightened out
21 replies to this topic
#16 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted June 08, 2011 - 08:04 PM
it drove about 2 miles then i parked it to put the battery in the dodge again, the truck barely started. so its not charging. any suggestions on where i should start? also is this a major problem? also she runs great and the goodyear turfs make some nice road noise. and i chased a deer lol.
#17 NUTNDUN OFFLINE
  • 10456 Thanks
  • 15622 posts
Posted June 08, 2011 - 08:16 PM
I am not real good with the electrical systems as far as charging. There are guys on here that are really good with it and I am sure they will be able to steer you in the right direction.
#18 caseguy OFFLINE
  • 1635 Thanks
  • 5600 posts
Posted June 08, 2011 - 08:22 PM
It would be really helpful to know what engine you're running. I'm not familiar with the Bolens to know what engine it has.
#19 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted June 08, 2011 - 08:23 PM
kohler k532
#20 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted June 08, 2011 - 08:32 PM
now i wonder if it has something to do with my voltage regulator. because the whole time i was running it the amp meter was in the negative a hair. like 1/8 of an inch give or take some
#21 NUTNDUN OFFLINE
  • 10456 Thanks
  • 15622 posts
Posted June 08, 2011 - 08:35 PM
I would start by checking your grounds, especially on the regulator. You should be able to test the leads going to the regulator to see if you have voltage going to the regulator. Also check to see if it is showing anything coming out.
#22 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted June 08, 2011 - 08:46 PM
i think tomorrow im going to shine up ALL my connections. and then see what happens.
