What is your favorite make and how is it special?
27 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 114 Thanks
  • 133 posts
Posted February 10, 2017 - 04:25 PM
I know a lot of people are partial to a particular make or series of tractors, but other than the case/ingersoll fans I don't hear much about why.  Is there something unique or special about your favorites that appeal to you?  If you were trying to convince me to buy one, what's your sales pitch?
  • hamman and chieffan have said thanks
#2 boyscout862 ONLINE
  • 13,229 Thanks
  • 9,289 posts
Posted February 10, 2017 - 04:45 PM
My favorite GT is my Bolens 1250. Its big, heavy and strong. Second favorite is an AC Big Ten for its versitility. I have plows, mower decks, snow blowers and a tiller for some of my Bolens. I have 20+ attachments for the AC/Simplitiys. It was hard to chose between them for the favorite spot. Good Luck, Rick
  • Alc, hamman, chieffan and 1 other said thanks
    Electric Tractors
  • 5,303 Thanks
  • 5,579 posts
Posted February 10, 2017 - 05:09 PM
GE ElecTrak garden tractors, they run without GAS. :thumbs:
  • Alc, hamman, boyscout862 and 3 others have said thanks
#4 propane1 OFFLINE
  • 8,972 Thanks
  • 4,222 posts
Posted February 10, 2017 - 05:14 PM
No favorites, they all have their good and not so good points. I use all of mine, they all have jobs.
  • hamman, boyscout862, Bill 76 and 2 others have said thanks
#5 Gtractor OFFLINE
    the homeless tractor hoarder
  • 9,485 Thanks
  • 5,001 posts
Posted February 10, 2017 - 06:38 PM
I don't really have a favorite.  I like all real tractors,  farm or garden.
I would be interested in several Sears Crapsman's though.  There is a sink hole out on the back 40 that needs filled in.
Fill dirt is high around here.  Rather use some kind of fill with no value.   :(
  • hamman, backwoods, boyscout862 and 2 others have said thanks
#6 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted February 10, 2017 - 07:20 PM
Depends on whatever fantasy you had about first successful one you had. As kid saw PK ads in mags and always wanted one. Then when about 50, Got one! Odd it was the SAME ONES I was liking back then!
  • Gtractor, hamman, boyscout862 and 1 other said thanks
#7 Bolens 1000 OFFLINE
  • 15,139 Thanks
  • 18,188 posts
Posted February 10, 2017 - 07:29 PM
I always loved and admired the Bolens line, they really were revolutionary and way ahead of their time in alot of designs and ways they built their equipment to be versatile and user friendly where children and wives could jump on them and do the lawn.
Also the fast switch attachment system which allowed you to change almost all the common attachments with no tools and no belts to align in minutes.
By the mid 60's the Tubeframe line had right around 40 different implements available
  • hamman, boyscout862, Eric and 2 others have said thanks
#8 grattone OFFLINE
  • 309 Thanks
  • 220 posts
Posted February 10, 2017 - 08:01 PM
I think a lot has to do with the purpose for the machine, what do you want to accomplish with it. I have a craftsman that I used to mow the lawn with, a panzer that pulls trailers around and is a back up for pushing snow, after I retired I purchased a Simplicity 7010 and use it to mow and push (what little snow we have). What makes things interesting is everyone has a different opinion and we can all smile. I even smiled when someone called my old mower a sears crapsman. (he is right / depending on what you compare it to )
  • Gtractor, backwoods, boyscout862 and 1 other said thanks
#9 chieffan OFFLINE
  • 10,418 Thanks
  • 6,742 posts
If it ain't RED Leave it in the shed.  Nothing smells like a JOHN.  Grew up around and on the Farmall line from the old Regular's up through the 450 international.  About that time Dad quit farming as I was in the service.  When I retired and was doing custom haying small squares it was a IH 400 and an H.  For the Gt line - Hard to pick between one of the Bolens or the White.
  • EricR said thank you
#10 Eric OFFLINE
  • 1,323 Thanks
  • 813 posts
Posted February 10, 2017 - 08:02 PM
I also like the bolens tractors, in particular the articulated versions. They for some reason remind me of working on aircraft. I see a lot of similarities in control cables and design. Not sure if they had any crossover in that field but working on Groundskeepers bring back fond memories and that is enough for me.
#11 toppop52 OFFLINE
  • 5,366 Thanks
  • 4,819 posts
Posted February 10, 2017 - 08:17 PM
My favorite is the one doing the job I need done.
  • boyscout862 and grattone have said thanks
#12 backwoods OFFLINE
  • 2,622 Thanks
  • 2,816 posts
Posted February 10, 2017 - 09:22 PM
Right now I would say the two that are together an run that being my cub 70 an my jd 212 both on snow duty. I'm not brand specific but if you look in the garage it's mostly deere, I've picked up the ones I have for either the attachments they have with them or the simple fact it's only a couple year production.
#13 larrybl OFFLINE
    Texas Member
  • Site Supporter
  • 7,096 Thanks
  • 4,450 posts
Posted February 10, 2017 - 09:50 PM
I would say the Sears (Near Sears Roper) and Craftsman are my favorites mainly for parts accessibly and solid transaxles. The Briggs twins are strong and easy to work on. There are weak areas, but mods to make them stronger can be made. I like the Ford LGT 165 but was afraid to do much work with it as it was $$$ to repair. The JD 165 Hydro is still new to us, but the 38" deck is a little small for the property. Main use machine is the 1990 Craftsman, Mows 2.5 acres regularly, For towing the trailer, the 1978 Roper is used, and for blade work, the 1988 Craftsman Hulk II.
The Roper 20T, 1988 BOH, and 1988 JD 165 are still doing Show duties, but will be put to work later on.
#14 WNYTractorTinkerer ONLINE
    Tinker Master
  • 10,654 Thanks
  • 5,849 posts
Posted February 10, 2017 - 09:58 PM
I've owned lots of different ones over the years..  Red, Orange, Black, Yellow, Blue and Green..  If it has wheels and a motor I'm in!
Edited by WNYTractorTinkerer, February 10, 2017 - 09:59 PM.
#15 EricR OFFLINE
  • 709 Thanks
  • 425 posts
Posted February 10, 2017 - 10:53 PM
Between my father and I we own 10 cub cadets and one jake, NOW we both like any old iron and that is one reason why I love this site, I like reading and seeing pictures about all of them!!!!!
