MotoMower Snowshark Manual?
5 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted February 10, 2017 - 12:23 PM
Does anyone have one handy? I need a sprocket on the darn thing and can't find a manual. Thank you!
#2 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted February 10, 2017 - 12:49 PM
The sprocket with the * on it is what I will need, along with the chain connecting it. Sprockets teeth rounded off on one side and the chain broke.
#3 boyscout862 ONLINE
  • 12,859 Thanks
  • 9,173 posts
Posted February 10, 2017 - 01:15 PM
If teeth rounded off, something was out of adjustment or alignment. Should be able to match it with chain pitch, number of teeth, and i.d.. Check with Wholesale Tool in Boston or Surplus Center in Lincoln, NE. Good Luck, Rick
#4 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted February 14, 2017 - 09:49 AM
Thanks Rick,
    I'm still trying to find these parts, does anyone have a manual for this machine?
#5 secondtry OFFLINE
secondtry
  • 1,902 Thanks
  • 1,387 posts
Posted February 14, 2017 - 12:36 PM
I don't know your area. Here in Spokane we have a store called North 40. It is a farm and ranch supply. in the hardware section they have a supply of blank hub sprockets of all sizes. the hubs are sold separate. You pick the sprocket with the proper pitch and tooth count, pick the hub for the proper shaft. they are machined to fit together. Couple of tack welds and you are good to go.  Don
  • Mark 149 J. said thank you
#6 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted February 14, 2017 - 01:20 PM
We have tractor supply co out this way.
