Predator engines?
19 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted February 06, 2017 - 08:18 AM
We've all seen or some have used the HF 6.5 engines and seem to like them. A few have used the 13 horse also, haven't heard much on how that went yet..   Latest ads show a V-twin, think was 22? hp or close for only $699.   Kinda look like Kohler design, but sure it isn't.  Just wondering if anyone has used one of those yet?  I think the Vanguards that are similar are great little engines, just wondered how these compare.  Not sure what size shaft either, does not say on the ads that I noticed.
#2 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted February 06, 2017 - 08:20 AM
not sure i had a project in mind that i was gonna get one for but ive changed plans an going a different route now
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted February 06, 2017 - 10:11 AM
I think that the v twin predators have a 1 1/8" shaft. Not 100% sure but I'm thinking that's what they are
Edited by Tecumseh power, February 06, 2017 - 10:12 AM.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted February 06, 2017 - 10:12 AM
That engine is a close copy of a Honda GX 630.
1" shaft. The killer is the 3 amp charging system. Barely adequate for a GT with an electric clutch.
  • Alc and chieffan have said thanks
#5 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 06, 2017 - 10:40 AM
I think with a little work the charging system could be changed out.
#6 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted February 06, 2017 - 11:11 AM
One thing I've noticed about Chinese scooter engines is they don't bother to fit the valves real well.  It's common for them to quit from tight valves at 700-1000 miles.  A Japanese engine typically has a service interval on valve lash of 15,000-20,000 miles and then they are seldom out of spec.
I'd bet the small engines are similar.  I'd stay on top of the maintenance if I were using one.
#7 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted February 06, 2017 - 11:32 AM
I have a 6.5 on my waste oil Vacuum Tank to run the vacuum pump.  Had to loosen the belt and take it off to to start with the recoil.  Also when cold out you have to remove the air cleaner and plug the hole in the choke butterfly to get enough fuel to it to start.
I threw away the recoil and air cleaner and start it with my Milwaukee cordless drill now and it will start with the belt on now.  Still have to plug the choke butterfly hole to get it going.  About 2 years old and still running.  It is an el-cheapo engine though.
#8 chieffan ONLINE
  • 11,374 Thanks
  • 7,118 posts
Posted February 06, 2017 - 12:58 PM
Have been around a couple of them. 10 hp the largest.  Had it on a wood spliter.  No hang power.  Old 10hp cast iron Briggs single would out work it 7 ways from sundown.
  • Bolens 1000, backwoods and karel have said thanks
#9 karel OFFLINE
karel
  • 2,329 Thanks
  • 1,496 posts
Posted February 06, 2017 - 05:14 PM
China Crap. Lasting value?
#10 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted February 06, 2017 - 07:45 PM
I tried replacing a engine in a gator with a 22hp and could not get the idle down below 13k, may be good idea to check on that.
#11 MFDAC OFFLINE
MFDAC
  • 3,592 Thanks
  • 1,710 posts
Posted February 06, 2017 - 08:13 PM
The 13 HP Preditor I had to re-power my MF12G with has run flawlessly for over a year now. Using it for mowing and plowing snow so it sees extreme temp differences. The only issue is if I let it sit and idle for more than 4 or 5 minutes it will start flooding a bit. I'm afraid I like this engine way better than the tired HH120 that came off. It uses half the gas as the HH120 did also.
I did recently notice that the Predator V-twin engines advertise cast-iron sleeved cylinders.
DAC
  • Cvans, backwoods and det12187 have said thanks
#12 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted February 06, 2017 - 10:29 PM
  I sure hope the "13k" is a typo!!
                                  Mike
#13 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted February 06, 2017 - 10:32 PM
  I think you can thank our good ol' EPA for the hole in the choke butterfly!!
                                      Mike
  • ducky said thank you
#14 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted February 06, 2017 - 10:43 PM
                                  Mike
Has to because the rod would break and flywheel would shatter at 13k
#15 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted February 07, 2017 - 08:08 AM
                                  Mike
It was , sorry
13 hundred , we needed to get it down to around 8-9 hundred to switch from forward to  reverse
Edited by grattone, February 07, 2017 - 08:11 AM.
