Moving dirt with the good ole 444
#1
OFFLINE
Posted June 06, 2011 - 12:02 PM
#2
OFFLINE
Posted June 06, 2011 - 12:08 PM
#3
OFFLINE
Posted June 06, 2011 - 12:59 PM
#4
OFFLINE
Posted June 06, 2011 - 03:34 PM
They can be tempermental sometimes but that is a really popular engine and there has to be some good advice out there if you feel up to tinkering with it.
- middleageddeere said thank you
#5
ONLINE
Posted June 07, 2011 - 06:21 AM
#6
ONLINE
Posted June 07, 2011 - 07:30 AM
#7
OFFLINE
Posted June 07, 2011 - 09:37 AM
#8
ONLINE
Posted June 07, 2011 - 10:33 AM
#9
OFFLINE
Posted June 07, 2011 - 10:59 AM
Casey , don't give up !! Sometimes those little leaks can be a pain , you'll get everything fixed . Al
#10
OFFLINE
Posted June 07, 2011 - 11:39 AM
As for your governor/throttle. From what I remember at the plow day, your throttle cable needs adjusted so it pulls the linkage tighter. It isn't pulling it far enough and putting enough tension on the governor spring the way it is right now, no matter where you move the spring.
You basically need to loosen the first throttle cable clamp closest to the carb and pull it back some but not too far to where you loose idle speed.
#11
OFFLINE
Posted June 07, 2011 - 01:58 PM
#12
OFFLINE
Posted June 07, 2011 - 02:04 PM
#13
OFFLINE
Posted June 07, 2011 - 02:23 PM
#14
OFFLINE
Posted June 07, 2011 - 02:56 PM
#15
OFFLINE
Posted June 08, 2011 - 06:18 AM
