I thought this would be easy, but...
Taking a 18322 tiller off of a 1467 (gear drive) and putting it on a 1668 (hydro).
Getting it attached was easy, except for the lift cable:
- I reversed the lift arm extension on the tiller so it is now offsetting to the right ("passenger side")
- added spacers between the lift arm and lift arm extension (adding more offset to the right). There is now a clear shot from the lift arm extension on the tiller to the hydro lift arm on the tractor (where the snowblower lift tube attaches)
- but cannot figure out where the lift cable roller (pulley) needs to be mounted. On the 1467G, there is a cross member above the axle with 2 arms, but not on the hydro.
Any help would be appreciated,
Thanks
Brad
