How much is "too much"?
16 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,483 Thanks
  • 1,402 posts
Posted January 31, 2017 - 01:44 PM
How much hp is "too much"?
I'm looking at a Massey 14, with a kohler k321 that apparently grenaded and puked out a puddle of oil...
I'm looking into repower candidates...
My dad suggested a 20 hp Briggs v twin
I'm interested in a diesel... but costs may prohibit that.
If I do go the v twin route, am I liable to encounter issues? I don't want to blow of the rear end...
Im open to suggestions for the repower
Edited by Greasy6020, January 31, 2017 - 01:45 PM.
#2 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted January 31, 2017 - 01:50 PM
Just go with another Kohler. A 14hp or a 16hp will be easy to do and won't overload anything. The extra effort to modify may not be worth it. Good Luck, Rick
  • MH81, tiretrx and Greasy6020 have said thanks
#3 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted January 31, 2017 - 01:55 PM
To me, the bigger question is what will this tractor be asked to do when all is said and done, engine wise?
Otherwise, I'll always vote for something that feasibly puts the most power to the ground.
  • Cvans and Greasy6020 have said thanks
#4 Greasy6020 OFFLINE
Greasy6020
  • 1,483 Thanks
  • 1,402 posts
Posted January 31, 2017 - 02:08 PM
Pull a plow, cultivator, push snow and dirt...
Just regular stuff.
And show off... I'm planning on putting straight pipes on
Edited by Greasy6020, January 31, 2017 - 02:13 PM.
  • tiretrx said thank you
#5 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted January 31, 2017 - 02:20 PM
Just regular stuff.
I see that as all stuff that the Massey could do easily with it's original size power plant, or similar. I guess after that it's a matter of how much work you want to do and how much you want to spend.
  • Greasy6020 said thank you
#6 James Bosma OFFLINE
James Bosma
  • 1,337 Thanks
  • 657 posts
Posted January 31, 2017 - 02:27 PM
About the easiest would be to go with another K241 (14 hp) or K341 (16 hp)
The K341 will bolt right in and have no issues with the driveshaft
The 16 hp has plenty of power for what you want to do
I found out almost a year of owning one of my MF14 has a K341 in it and has plenty of power for snow blowing, front blade, 12 inch - 1 furrow plow, rototiller, and mower deck.
Haven't had the chance to try a cultivator or disc behind mine yet but think it will handle them with no problem
  • tiretrx, boyscout862, propane1 and 1 other said thanks
#7 Greasy6020 OFFLINE
Greasy6020
  • 1,483 Thanks
  • 1,402 posts
Posted January 31, 2017 - 02:29 PM
Ok, I'm thinking about finding one now...
  • James Bosma said thank you
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 31, 2017 - 06:13 PM
I'd say like the others put another 14hp or 16hp Kohler K series in it.
Here's a decent running 14     I picked up for a friend couple yrs ago.
https://www.youtube....h?v=SH5iOIPAj14
#9 dodge trucker ONLINE
dodge trucker
  • 2,456 Thanks
  • 3,136 posts
Posted January 31, 2017 - 06:15 PM
The 14 HP Kohler has at least as much power s that 20hp twin and a freshened up one will outlast and outwork the newer engine too.
#10 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted January 31, 2017 - 06:18 PM
I also say put a k321 or k341 back in. My 16 has yet to meet its match. I've skidded logs, mowed, and pulled a 12" plow without issues.
Eric
#11 poncho62 ONLINE
poncho62
  • 1,766 Thanks
  • 1,668 posts
Posted January 31, 2017 - 06:56 PM
Have you taken the K321 apart yet to see if it can be fixed/rebuilt?
#12 Greasy6020 OFFLINE
Greasy6020
  • 1,483 Thanks
  • 1,402 posts
Posted January 31, 2017 - 08:02 PM
No, I don't have anywhere to do so, or even have the tractor home
#13 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted January 31, 2017 - 08:08 PM
You can disassemble a kohler K anywhere. You'd be suprised. There's not much to them. I've honed, reringed, and repaired a governor gear (initial reason for teardown) in less than a day. Used it that evening for some blade work! Hand tools, feeler gauge, and a torque wrench. Your good to go.
Eric
Edited by dropped82, January 31, 2017 - 08:09 PM.
  • karel and Greasy6020 have said thanks
#14 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted January 31, 2017 - 09:36 PM
You don't have room for a rebuild, but you have room to do a repower?!?
  • dropped82 said thank you
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,341 Thanks
  • 9,800 posts
Posted February 01, 2017 - 07:54 AM
I've been told that Wheel Horse transaxles can  tolerate up to about 35hp. Cub Cadets can handle motorcycle and car engines. I'm not familiar with the trans used in MFs.
