Where to buy a drive shaft for a GT 16 48 inch mower deck?
17 replies to this topic
#1 whymecoyote OFFLINE
whymecoyote
  • 19 Thanks
  • 23 posts
Posted January 30, 2017 - 09:54 PM
Where to buy a drive shaft for a GT 16 48 inch mower deck? The one I have is just a little too short and an internet search seems to tell me that the mower deck drive shaft is longer than the snow blower shaft. Also the tractor engine dies when I engage the front pto. Any help?
#2 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted January 30, 2017 - 10:03 PM
Look on ebay and be prepared for the sticker shock.
As for the engine dying, there's most likely something wrong in the safety circuit.
There's a link in here to the manual and the electrical troubleshooting.
Sent from my SM-G920P using Tapatalk
  • whymecoyote said thank you
#3 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,500 posts
Posted January 31, 2017 - 07:13 AM
yup, that is a bad thing about the Ariens line is their PITA safety cutouts, seems there should be a better way. I have 2 of them driving me crazy right now. Took a break from mine to do other things in the garage.
#4 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,703 posts
Posted January 31, 2017 - 07:15 AM
Agree with above. Is the seat switch connected?
#5 whymecoyote OFFLINE
whymecoyote
  • 19 Thanks
  • 23 posts
Posted January 31, 2017 - 07:29 AM
The seat switch is shorted with a wire that I disconnected and then tried to start my tractor. It would not start so I reconnected it and all is well in that way. The PTO still kills the engine. Where are the other safety switches? How many? There are two PTO switches. Could I just use the rear PTO switch? There is no rear PTO installed.
Edited by whymecoyote, January 31, 2017 - 07:32 AM.
#6 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted January 31, 2017 - 12:11 PM
There's the seat switch, park switch, 1 or 2 pto switches, and depending on the model ether old transistor board or the newer time delay interlock.
With the engine running, in neutral not park, and you get off the seat, does it die? Continue running if you sit back down quick?
Bypassing the old transistor board is simple enough. I wrote how to somewhere in here. That's how I've done my loader tractor beings the transistor boad went bad.
Bypassing the time delay is an issue I have yet to figure out.
#7 whymecoyote OFFLINE
whymecoyote
  • 19 Thanks
  • 23 posts
Posted January 31, 2017 - 12:59 PM
It has never died when I got off the seat.
#8 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted January 31, 2017 - 01:07 PM
http://gardentractor...illing-My-Gt17?
If you have the transistor boad.
#9 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted January 31, 2017 - 01:09 PM
http://gardentractor...lock/time-Delay
Time delay interlock.
#10 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted January 31, 2017 - 01:11 PM
The manual
http://gardentractor...-on-Ariens-GT20
#11 whymecoyote OFFLINE
whymecoyote
  • 19 Thanks
  • 23 posts
Posted January 31, 2017 - 08:35 PM
I have not looked at your links yet but after unplugging and cleaning the PTO switch and ignition switch I found a very burned part on the board.
#12 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,500 posts
Posted February 01, 2017 - 06:12 PM
question about the seat switch;
I have a couple of good seats here (not Ariens but I don't care, can't see that when I'm sitting on it)  that do not have the seat switch incorporated. I know about the hour meter running constantly if the seat switch is bypassed,  how could I use the seats that I have laying around on a setup that incorporates a stupid switch?
#13 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,703 posts
Posted February 01, 2017 - 10:00 PM
What about a toggle for a switch on there? But then you need to remember that.
#14 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted February 01, 2017 - 10:14 PM
Wire through the key switch with a relay somehow?
#15 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,500 posts
Posted February 02, 2017 - 04:45 PM
Ultimately if I fix this the way that I want to the whole thing will be rewired and the idiot proof system will be moot. Someday.
