Bolens snowcaster 18538 chute control
11 replies to this topic
#1 racrawfo OFFLINE
racrawfo
  • 2 Thanks
  • 9 posts
Posted January 30, 2017 - 09:49 PM
Does anyone have a list of after market chute control levers or a site to purchase originals? I appreciate any info!
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • MyBolens1053 said thank you
#2 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 30, 2017 - 09:55 PM
One of our other sponsors should have either new or used available, I do not have any at this time
  • boyscout862 and MyBolens1053 have said thanks
#3 racrawfo OFFLINE
racrawfo
  • 2 Thanks
  • 9 posts
Posted January 30, 2017 - 11:10 PM
Thanks, I will look for the right sponsor.
#4 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted January 31, 2017 - 12:12 PM
Good luck to finding one. Shouldn't be too hard.
And while on the subject of the 18538 how does one stop the spinning of the chute from vibrations of the tractor and auger?
Thanks.
#5 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 31, 2017 - 01:21 PM
Thanks.
Theres a stop screw on the main body of the control rod housing you can tighten to add resistance to the hand crank rod.
#6 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted January 31, 2017 - 01:26 PM
Wasn't sure what that was.Thanks for that info. Are there any other items of concern on these casters? I don't have an Owner's Manual. Just the breakdown and parts list.
#7 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 31, 2017 - 01:28 PM
If you keep the gear box and bearings lubed these will last forever
#8 racrawfo OFFLINE
racrawfo
  • 2 Thanks
  • 9 posts
Posted January 31, 2017 - 01:38 PM
For now I will have to settle for disengaging the pto and moving the chute by hand until I find one.
#9 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted January 31, 2017 - 02:27 PM
Which pieces do you need? I should be able to help.
  • Bolens 1000, Bruce Dorsi and 29 Chev have said thanks
#10 racrawfo OFFLINE
racrawfo
  • 2 Thanks
  • 9 posts
Posted January 31, 2017 - 03:37 PM
Item 4 all the way out to the handle. Item 4 snapped in half on me and the handle that you rotate is bent.
#11 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted January 31, 2017 - 04:25 PM
I should have have most, if not all of that. I'll take a look and send you a PM.
  • Bolens 1000 and Bruce Dorsi have said thanks
#12 racrawfo OFFLINE
racrawfo
  • 2 Thanks
  • 9 posts
Posted January 31, 2017 - 05:01 PM
Okay, thanks!
