Cub Cadet 7195 with loader
11 replies to this topic
#1 EricFromPa ONLINE
EricFromPa
  • 3,519 Thanks
  • 3,067 posts
Posted January 29, 2017 - 04:17 AM
This might interest a few people here.Says it runs and everything works on it but it won't move.Should be easy enough to fix since the hydraulics still work fine.Or pull the loader and engine out of it and put them on/in a garden tractor?
Model #7195 year 96 3 cylinder diesel 19hp rebuilt motor runs great everything works except won't move is hydrostatic asking 1500 obo text/call 724-664-9622
Mayport, PA
http://classifieds.r...adindex=4266121
  • limebuzz, Alc, KennyP and 3 others have said thanks
#2 chieffan ONLINE
  • 9,569 Thanks
  • 6,408 posts
Posted January 29, 2017 - 07:55 AM
If it was a lot closer - - Would part out for the $1500.
#3 diesel nut OFFLINE
diesel nut
  • 685 Thanks
  • 421 posts
Posted January 29, 2017 - 11:57 AM
For that kind of money its almost worth it worth it for me to drive down to get it. Most likely it just needs a clutch to make it drive again
Edited by diesel nut, January 29, 2017 - 11:59 AM.
#4 olcowhand OFFLINE
  • 40,354 Thanks
  • 31,172 posts
Posted January 29, 2017 - 12:02 PM
That is an awesome deal, even if hydro is toast!
#5 glgrumpy OFFLINE
  • 8,559 Thanks
  • 7,878 posts
Posted January 29, 2017 - 02:18 PM
Looking at front tires....is this 4 x 4?  This must be big model for them with roll-bar and bigger tires and etc.  I'm not familiar with these, but looks like nice tractor size. This one was not cared for too well, but next guy might treat it better??  What is this ad paper? New to me, and can't really figure out Where this is from?
#6 olcowhand OFFLINE
  • 40,354 Thanks
  • 31,172 posts
Posted January 29, 2017 - 02:32 PM
Year 1997, 4WD hydrostatic.
#7 EricFromPa ONLINE
EricFromPa
  • 3,519 Thanks
  • 3,067 posts
Posted January 29, 2017 - 10:17 PM
New Clutch for it on Ebay with pressure plate and bearings for $190 + $13 shipping
http://www.ebay.com/...725.m3641.l6368
#8 olcowhand OFFLINE
  • 40,354 Thanks
  • 31,172 posts
Posted January 29, 2017 - 10:42 PM
Stats show the 7195 is hydro only.
#9 diesel nut OFFLINE
diesel nut
  • 685 Thanks
  • 421 posts
Posted January 29, 2017 - 11:52 PM
The tractor still has a single stage clutch in it.  I'm pretty sure it's for the rear pto because the over running coupler for it is attached to the back side of the input shaft on the hydro
  • olcowhand said thank you
#10 EricFromPa ONLINE
EricFromPa
  • 3,519 Thanks
  • 3,067 posts
Posted January 30, 2017 - 01:43 AM
Did some digging and found some info on it.
7195 was available with HST Hydro and something called dual gear drive.They also had a dual gear drive 2 wheel drive but the hydro is 4WD.HST hydro has a hydro disconnect clutch and dual brakes.Also has a 2 speed rear with Diff lock.It's a Decent little machine.Not much bigger than a large garden tractor.
Parts list and stuff on partstree.
https://www.partstre...-cadet-tractor/
HST hydro and gear drive Clutches here.
https://www.partstre...tch-hst-single/
HST hydro Pedals here.Hydro disconnect clutch pedal is on the opposite side of the brake pedals.
https://www.partstre...-b-control-hst/
IH CC offered the optional Cub Cadet 428 Disconnect Clutch Kit for garden tractors years ago.I would imagine the 4WD HST Hydro needs a clutch so it can slip a bit instead of twisting off the input shaft on the hydro pump.It's setup very similar to a garden tractor.Pump is mounted to the front of the diff and runs off of the driveshaft.
Here's the pump.
https://www.partstre...ion-hst-part-1/
Edited by EricFromPa, January 30, 2017 - 02:29 AM.
  • olcowhand, limebuzz and Leonard VanCamp have said thanks
#11 olcowhand OFFLINE
  • 40,354 Thanks
  • 31,172 posts
Posted January 30, 2017 - 10:00 AM
I definitely learned something!
#12 EricFromPa ONLINE
EricFromPa
  • 3,519 Thanks
  • 3,067 posts
Posted January 30, 2017 - 03:27 PM
Wish I could scrounge up some money.Get it for around $1200 and buy a clutch and a couple quarts of paint for it.I probably could but I would have to sell pretty much everything I have that's worth anything lol.
That little Mitsubishi K3E is worth the asking price if it runs good.
