cub 1811
running rough
24 replies to this topic
#1 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted January 26, 2017 - 01:29 PM
I have a cub with a kohler magnum 18 and it is running rough and not to familiar with this motor
 Have changed the plugs and fresh gas. I got this cub 1811 and it has been sitting in a garage.
It looks like it has been worked pretty hard.
Any suggestions would be nice.            Thanks Dave!
  • toppop52 said thank you
#2 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,581 posts
Posted January 26, 2017 - 01:44 PM
I have the same tractor.  If the tractor has been sitting for some time, it's most likely the carb. needs to be rebuilt.  They are a very simple carb. to take apart, clean, and reassemble. You can even find videos on youtube that will show you how to rebuild them.
Another problem that these engines have is the fuel pump.  The pump diaphram will tear and leak gas into the oil of the engine.   Just remove the dipstick and smell the oil for gas.  You can also download the engine manual from the manual section of this site.
Good luck!
  • KennyP and Loon64 have said thanks
#3 toppop52 OFFLINE
toppop52
  • 5,538 Thanks
  • 4,901 posts
Probably needs a thorough carburetor cleaning, common issue nowadays.
  • Loon64 said thank you
#4 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted January 26, 2017 - 01:56 PM
Thank's I'll try that. It sounds like it should be electrical because it is skipping
  • Mark 149 J. said thank you
#5 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,581 posts
Posted January 26, 2017 - 02:56 PM
Assuming "skipping" means missing.   This can be due to lack of fuel.  Lack of fuel makes the engine run lean causng a misfire.  Dirt and corrosion can plug the ports in the carb reducing the amount of fuel making it to the cylinder.  This is a common problem when any engine sit for a while.  It is possible that you have a problem with a plug wire or even the coil but because it's been sitting I'd start with the carb.  If one cylinder is consistanly missing all the time then it could be due to lack of compression in that cylinder.  I replaced the head gaskets and resurfaced the head to make it flat on my 1811.  I did this because the compression was low.  This is something that you can check later if the carb. rebuild doesn't fix the problem.
Also, make sure the cooling fins on the engine are clean of dirt, grease, and grass by removing some of the tin around the engine and blowing compressed air to remove the debris.
#6 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted January 26, 2017 - 03:02 PM
Thank's, Alot to take in but one step at a time.
#7 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,581 posts
Posted January 26, 2017 - 03:06 PM
That's a great way to accomplish anything!
#8 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted January 27, 2017 - 05:42 PM
pulling my log splitter today and the 1811 fouled both plugs?
 Starting to think $500 was a little mutch
#9 olds45512 ONLINE
olds45512
  • 1,405 Thanks
  • 699 posts
Posted January 27, 2017 - 07:23 PM
when my 1811 was doing that I rebuilt the carb and it ran great, it's most likely just in need of a good cleaning and make sure you adjust the float properly.
#10 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted February 23, 2017 - 05:33 PM
replaced fuel pump and rebuilt the carb and plowed a lot snow! Thanks Again!!
#11 KennyP ONLINE
  • 40,896 Thanks
  • 47,099 posts
Posted February 23, 2017 - 05:44 PM
So it's running good again?
#12 Loon64 OFFLINE
Loon64
  • 110 Thanks
  • 71 posts
Posted February 23, 2017 - 06:27 PM
Ya not bad, I'd like to change the plug wires but it looks like I'd have to take off the oil filter lines or pull the motor
#13 KennyP ONLINE
  • 40,896 Thanks
  • 47,099 posts
Posted February 23, 2017 - 06:31 PM
It has a remote filter? I have an M18, but it's running real sweet.
  • Loon64 and Mark 149 J. have said thanks
#14 olds45512 ONLINE
olds45512
  • 1,405 Thanks
  • 699 posts
Posted February 23, 2017 - 07:56 PM
the plug wires are not replaceable, they're part on the magneto which costs around $80.
#15 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,581 posts
Posted February 23, 2017 - 09:31 PM
Good!
