Kohler command 16hp oil block off plate?
kohler
8 replies to this topic
#1 kmm0912 OFFLINE
kmm0912
  • 92 Thanks
  • 49 posts
Posted January 24, 2017 - 11:16 PM
Need to find out, Kohler command 16hp engine equipped with an oil filter....
Does the oil HAVE to travel through the oil filter to properly lube the engine.
Basically, can I put a block off plate in place of the filter.
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted January 25, 2017 - 01:53 AM
I would not recommend removing the filter as the manufacturer put it there for a reason. I don't have any experience with that motor but it is always better to be safe than sorry. If it happens that your filter is inoperable for some reason you may be able to rebuild it or find an in line oil filter and then make or buy a block off plate.
#3 chieffan OFFLINE
  • 11,377 Thanks
  • 7,120 posts
Posted January 25, 2017 - 08:08 AM
I agree with Eric.  That filter was put there to filter the impurities out of the oil.  Put a new filter on and forget about any blocking off.  Just asking for trouble in my opinion.
#4 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted January 25, 2017 - 08:14 AM
There won't be anyway for the oil to circulate with out it.
#5 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,418 posts
Posted January 25, 2017 - 09:57 AM
Is this for a repower with little room for the filter?
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted January 25, 2017 - 01:23 PM
If space is the issue with using the stock filter in it's proper location, remote oil filter kits are available.
#7 kmm0912 OFFLINE
kmm0912
  • 92 Thanks
  • 49 posts
Posted January 25, 2017 - 02:35 PM
Yes.
#8 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 26, 2017 - 04:30 AM
You need to find a remote oil filter kit for it. As it needs that filter to live a long prosperous life.
#9 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,418 posts
Posted January 26, 2017 - 05:58 AM
Like others have said, explore the remote filter a bit. Depending on your application there might not be room for the lines either.
Also tagged with one or more of these keywords: kohler
