Troy-Bilt 3000 psi pressure washer
6 replies to this topic
#1 Joey davies OFFLINE
Joey davies
  • 1 posts
Posted January 24, 2017 - 06:22 PM
I have an 8.75 horsepower, 190 CC pressure washer. I clean the carburetor and jets, check the load valve, and am able to start and run the motor with the water hose connected. Water shoots out the port strong, so I hook up the spray hose and gun. I can start the motor and it runs with the gun trigger as long as there's no tip on it. As soon as I put a spray on my wand the motor stalls out. Only the black tip with the large hole works on the wand to keep the motor running as long as I have the trigger pulled. Once trigger is released, the engine stalls again. It was working great up until the last time I used it a week ago. I called Briggs and Stratton tech support and they had never heard of this condition. Any speculation would be greatly appreciated at this point LOL thank you
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted January 24, 2017 - 07:57 PM
It sounds like a problem with the pump possibly. Not sure of the workings of your machine.
#3 secondtry OFFLINE
secondtry
  • 1,688 Thanks
  • 1,288 posts
Posted January 24, 2017 - 08:29 PM
Unloader valve not functioning? Don
  • boyscout862 and Eric have said thanks
#4 bhts OFFLINE
bhts
  • 1,465 Thanks
  • 2,161 posts
Posted January 24, 2017 - 09:42 PM
I have to agree. Sounds like it is stuck. Do not keep running it this way as it may damage it. You need to check this valve and make sure something has not got in it and jammed it.
#5 boyscout862 ONLINE
  • 12,552 Thanks
  • 9,046 posts
Posted January 25, 2017 - 08:28 AM
Welcome to GTT. It may be in the pump so check that thoroughly first. If the problem persists, I would suspect the governor on the engine and the carb. Good Luck, Rick
#6 chieffan OFFLINE
  • 9,609 Thanks
  • 6,427 posts
Posted January 25, 2017 - 08:35 AM
I don't think it is in the engine.  Like the other have said, unloader valve is stuck.  My Coleman did the same thing a year or so ago.  Cleaned it up and has worked fine ever since.
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted January 25, 2017 - 10:05 AM
Do a Google search for "Troy-Bilt unloader valve."
Lots of links about the same problem and how to clean, repair.
