Air compressor help.
18 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted January 22, 2017 - 03:58 PM
I'll start with a little background.
I recently moved and the compressor came with me. I drained the oil laid the compressor down , moved it and now fast forward to this week. I filled it with the correct oil following the manual for amount as well. I wired it up and started it. 40 seconds later it shut off. The compressor has a low oil shut off factory installed. That switch is the culprit, I hit the reset and only went for 5-10 seconds.
So here's the question??
Do you think the switch needs to replaced, or there is something ( dirt) screwing it up? So far the only thing I could find ( online)was that it may have a filter/ screen that could be dirty/clogged. Here's a pic of the low oil switch. It's a champion compressor model VR5-8
Similar to this pic but with the automatic tank drain, bigger motor with a magnetic starter and the low oil shutoff. image.jpg
Any suggestions welcome.
Edited by TomLGT195, January 22, 2017 - 03:59 PM.
#2 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 22, 2017 - 04:21 PM
   well if it can be taken apart and cleaned you should try that first otherwise you could bypass it to just get the comp running (not recommended) How much is a new switch? maybe just replace if not to expensive just to get the peace of mind.
        Pete
  • TomLGT195 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted January 22, 2017 - 05:23 PM
        Pete
That's the plan I hope. This week I'll try taking it apart. I did post this question on an air compressor site too , hope to get a diagram of what I'm up against before I "pop" it open.
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 22, 2017 - 05:29 PM
  I'd remove the three screws and try to find what's wrong if possible.
                                       Mike
#5 Cvans ONLINE
  • 6,467 Thanks
  • 6,058 posts
Posted January 22, 2017 - 05:32 PM
That switch looks to be pressure operated. Is this true? Some sense the level. I wouldn't be operating it until you know for sure that you have oil pressure.
#6 Bill 76 OFFLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted January 22, 2017 - 05:50 PM
If you laid it on its side maybe air got in the lines , Try cracking the lines loose and start it up to bleed them out.
#7 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted January 22, 2017 - 05:55 PM
Yeah, I bet air in passages and no oil getting to the switch. Can you back it out and let oil run out a bit?  Let enough come out to make sure Whole passage is filled. OR, is there a screw to pull and use an oil gun or ??? to squirt some oil into system?
#8 pryan05 ONLINE
pryan05
    LGT
  • 617 Thanks
  • 342 posts
Posted January 22, 2017 - 06:14 PM
My thoughts too.
#9 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted January 22, 2017 - 07:29 PM
That's one of my thoughts.
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted January 22, 2017 - 07:31 PM
Another option I've thought about.
#11 Alc ONLINE
  • 6,748 Thanks
  • 7,398 posts
Posted January 23, 2017 - 06:27 AM
I didn't know compressors had low oil switches or pressure switches .   Mine must be too small and old .
#12 Cvans ONLINE
  • 6,467 Thanks
  • 6,058 posts
Posted January 23, 2017 - 11:23 AM
 Some do but unfortunately not all catch the low oil soon enough. One of our maintenance men found that out the hard way.  :mad2:
#13 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 23, 2017 - 11:49 AM
If not looking at the switch or bleeding the lines,,( ALL good tips )  Doe's the oil resevoir have a  float of some kind, that may have been tilted and hung up when  laid on it's side..??? may be a little time to let it settle back down ( Kinda like a frig ) to let the coolant,, oil  what-ever  find home again...    Just a thought...   good luck anyway...
#14 ducky ONLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 23, 2017 - 12:00 PM
That is a pressure switch.  The pump may have lost its prime.  Can you take a line off and get some oil into the pump to prime it?
  • KennyP and TomLGT195 have said thanks
#15 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted January 23, 2017 - 03:46 PM
This is a commercial model.
