Roto Rugg Project
35 replies to this topic
#31 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted June 25, 2011 - 09:35 PM
I pulled the coil today, and am a bit perplexed as it all came off in one piece. The coil is EarthBird 008.jpg
#32 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted June 25, 2011 - 10:08 PM
I have never seen one that way, but back in the day, you may have changed the whole thing.
#33 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted June 27, 2011 - 08:02 PM
Am getting fed up here. More than likely gonna purchase one of these!
IGNITION MODULE Kit Small Engines For B&S Tec Kaw Other | eBay
#34 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4,007 Thanks
  • 2,485 posts
Posted June 29, 2011 - 02:59 PM
I pulled the coil today, and am a bit perplexed as it all came off in one piece. The coil is [ATTACH=CONFIG]16358[/ATTACH]riveted to the plate. I am not familiar with this setup. How do you change the coil? Do you have to drill out the rivets to replace or what? I have included a picture of front and rear. [ATTACH=CONFIG]16357[/ATTACH]
I apologize for the delay in getting this Clinton info for you.
Your model VS-1100 engine is here: Clinton VS-1100-1000 series engine - Manuals - Garden Tractor Talk - Forums
Info on the recoil starter is here: Clinton Recoil Starters - Manuals - Garden Tractor Talk - Forums
The black ignition coil can be removed from the steel laminations it is mounted on. .....You do not have to replace the entire assembly. .....A #30560 Tecumseh coil should fit on the laminations, and a # 30548 Tecumseh condenser should work also.
The electronic ignition module which you posted will only eliminate the points & condenser. ....If your coil is bad, you still will not have any spark.
#35 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted July 27, 2011 - 05:04 AM
Slow progress, as my mowing has taken up so much of my free (?) time up. Update! I have ordered a condensor for the old VS1100! Should be here anytime now. I am hopeful that will do the trick to getting her spark. If that is the case, then I will plug along slowly but surely on my neverending Roto Rugg project. Stay tuned for further developments.
#36 caseguy OFFLINE
  • 1,629 Thanks
Posted July 27, 2011 - 07:59 PM
Thanks for the update! Still watching!
