Charging system?
54 replies to this topic
#46 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted March 19, 2017 - 05:18 PM
Check for output from the switch?
#47 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted March 19, 2017 - 06:30 PM
I checked every terminal on the switch, power at the hot terminal but nothing at the coil or any other terminal in the on or start position of the switch, could I have killed the switch when the charging system started working? Thinking the switch is the part that failed, not the relay.
#48 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted March 19, 2017 - 08:20 PM
I think you hit it there. Its been a while, but I am remembering 2 outgoing hots.
#49 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted March 19, 2017 - 09:50 PM
Yep, two outgoing hots, one ingoing, charge wire, not sure what #5 is, but switch is dead, do you by chance have a part number?
#50 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted March 20, 2017 - 05:15 AM
It is a common Indak ignition. I can check to see if I have a number tonight.
  • adamjd200 said thank you
#51 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted March 20, 2017 - 08:15 AM
I'll just make note of the terminals, and take the switch with me to my local shop, he'll match it up from there.
#52 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted March 26, 2017 - 12:23 PM
One issue fixed, now for that ground wire.
#53 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted April 16, 2017 - 09:21 PM
It did it again:(, dig a little deeper and the plug for the ignition switch is crap at best. Got a new plug with wires, gonna splice it in and eliminate the most of the crap wiring in the process, can move it right now by hot-wiring the coil wire to the battery and crossing the solenoid.
#54 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted May 20, 2017 - 08:31 PM
New plug is installed, works good now.
  • shorty said thank you
#55 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted May 30, 2017 - 06:54 PM
And the saga continues, it's charging but not nearly enough, 11v at the regulator, wondering if the regulator is bad as the rest checks out.
