jd 112l
5 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 05, 2011 - 11:57 AM
i just got a jd 112l the motor is half tore4 apart i got it from my inlaws they told me that they were told it needs a new engine they said that when they took it to the shop it would run for a few mins and quit any ideas what would cause this the piston looks fine and so i would like to fix it thanks for any help
#2 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted June 05, 2011 - 12:34 PM
The 112L was made only one year, 1985. It has a 12.5 hp Kawasaki engine on it. It's basically a 111 with a Kawasaki engine instead of a Briggs. That same engine used in the 112L was in the 160 and 165 lawn tractors. You could also repower using a Briggs single cylinder engine. I have the 1985 brochure that has the 112L in it upload. 1985 LT & RER brochure - Manuals - Garden Tractor Talk - Forums
You probably could use the 160/165 service manual for the engine: JD Tech 130/160/165/170/175/180/185 - Manuals - Garden Tractor Talk - Forums
#3 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 05, 2011 - 01:16 PM
ok i have a 11hp briggs in a old simplicty would that work and what else would i need to change
#4 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted June 05, 2011 - 04:37 PM
You have to know the sizes of the crank. If the crank from the Briggs is the same as the existing engine, then it should work. Also check the mounting hole locations. Wiring may have to be modified a bit.
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 06, 2011 - 04:01 PM
the engine i have is a briggs model 253707 0182-02 everything looks like it will go the only problem i have found is the briggs is a virtical fed engine and the 112l has a vaccum fuel pump any ideas on how to hook that up
#6 better before OFFLINE
better before
  • 2 Thanks
  • 13 posts
Posted August 02, 2011 - 06:56 AM
The fuel pump from the kawi will work. You need the breather/ valve cover combo for the briggs to get the vacuum to run the pump and you will be golden.
