Clutch Alignment Tool
9 replies to this topic
#1 Harold Cole OFFLINE
Harold Cole
  • 1 Thanks
  • 7 posts
Posted January 19, 2017 - 12:27 AM
replacing Clutch,Preasure Plate and throw Bearing on my 2416 and am of need for a clutch alignment tool.Does anyone know where to purchase one.Thanks Harold
#2 Cvans ONLINE
  • 6,285 Thanks
  • 5,986 posts
Posted January 19, 2017 - 12:49 AM
If you can't find one you can make one out of a wooden dowel or use a socket with the right outside diameter.
  • grattone said thank you
#3 glgrumpy OFFLINE
  • 8,494 Thanks
  • 7,850 posts
Posted January 19, 2017 - 04:12 AM
If not too heavy, Trans can be held up and snug bolts.
#4 Harold Cole OFFLINE
Harold Cole
  • 1 Thanks
  • 7 posts
Posted January 19, 2017 - 09:47 AM
Thanks for the replies,I think the Trans is too Heavy
#5 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 7,473 Thanks
  • 2,458 posts
Posted January 19, 2017 - 12:01 PM
If you have access to a wood lathe you could turn one out of wood sized to the pilot bushing / bearing and clutch hub centre - just a suggestion if you can't find one.
#6 MiCarl ONLINE
MiCarl
  • 1,828 Thanks
  • 986 posts
Posted January 19, 2017 - 12:39 PM
I have a kit I purchased years ago from an auto parts store.  Don't they still have them?
For that matter, many of the big chain auto parts stores have "loan-a-tool" programs.  You might be able to get one that way.
Of course if you have a spare transmission input shaft on hand you can just use that.
Edited by MiCarl, January 19, 2017 - 12:39 PM.
#7 chieffan OFFLINE
  • 9,128 Thanks
  • 6,232 posts
Posted January 19, 2017 - 12:52 PM
Put a jack under it.  Done that several times with a full size auto.
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 19, 2017 - 06:21 PM
Take a big allen wrench that fits or almost fits the pilot hole. Find a socket that fits the clutch plate. Slide the allen wrench inside the socket. Duct tape wrapped around both to adjust the size to a snug fit. Easy-pessy, Good to go. Did this once on a buddy's car. Worked like a charm.
Edited by Bmerf, January 19, 2017 - 06:22 PM.
  • Alc, HANKG and 64fleetside have said thanks
#9 JBRamsey ONLINE
JBRamsey
  • 1,353 Thanks
  • 786 posts
Posted January 19, 2017 - 08:21 PM
Advance Auto, NAPA, Autozone. Or cut a piece of broom handle. I wouldn't do the duct tape thing, because I would not want to unwrap it after I was finished.
#10 SimplyRad OFFLINE
SimplyRad
  • 984 Thanks
  • 759 posts
Posted January 20, 2017 - 09:22 AM
Back in my machinist days I needed one for a ford clutch so I made one out of steel but don'r have a lathe today.
