Battery Size.
15 replies to this topic
#1 adamjd200 ONLINE
adamjd200
  • 1,881 Thanks
  • 2,009 posts
Posted January 18, 2017 - 11:53 PM
Is a 340cca battery big enough for a k321 Kohler? This tractor has a small car battery in it now.
#2 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 8,302 Thanks
  • 4,566 posts
Posted January 19, 2017 - 12:17 AM
That should be fine if your cables are good,  you have a good ground, and your ACR is working.
#3 adamjd200 ONLINE
adamjd200
  • 1,881 Thanks
  • 2,009 posts
Posted January 19, 2017 - 12:26 AM
Cables are a non-issue as I will be making new ones.
#4 classic ONLINE
classic
  • 4,643 Thanks
  • 2,053 posts
Posted January 19, 2017 - 12:33 AM
I recently rebuilt a Delco starter generator for my Power king tractor with a 9hp Briggs. I replaced the bearings, cleaned the commutator ( where the brushes ride ), and replaced the brushes. I also sprayed the dust and grime out of the case and armature with Lectra-Motive electric motor cleaner. I took a very small diameter pulley from another starter generator to get more torque out of it. I have a Sears DieHard Gold garden tractor battery in it from 2011 that came in a Sears SS-18. On the coldest days this tractor fires right up with no problem. These starter generators need to be serviced regularly to keep them functioning 100%. I remember reading that they should be serviced annually on a tractor that sees regular use. 340cca is just fine if the electrical system is in order.
#5 adamjd200 ONLINE
adamjd200
  • 1,881 Thanks
  • 2,009 posts
Posted January 19, 2017 - 11:14 AM
This is on an Ariens, not a starter generator engine, I want to charge the old battery and double check everything before I put a new one in.
  • classic said thank you
#6 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted January 19, 2017 - 11:32 AM
The K321AQS in my 1450 Cub has a smaller battery and has no trouble cranking and starting, and it has to crank a bit in the cold.  I need to soup up the ignition this year.
#7 chieffan ONLINE
  • 8,356 Thanks
  • 5,784 posts
Posted January 19, 2017 - 12:55 PM
On tractor I plan to keep I put in the biggest CCA and physical size that will fit.  Make sure your starter is good.
  • Leonard VanCamp said thank you
#8 ducky OFFLINE
  • 1,961 Thanks
  • 4,085 posts
Posted January 19, 2017 - 03:57 PM
340 CCA. is more than enough.
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,367 Thanks
  • 4,074 posts
Posted January 19, 2017 - 05:53 PM
If you have the nylon starter gear like many Craftsman's be careful with anything above 340cca, I installed a 420cca and proceeded to blow the starter gear to smithereens. Battery is still in there, but I bought several new nylon gears.
  • Cvans said thank you
#10 poncho62 ONLINE
poncho62
  • 1,092 Thanks
  • 1,404 posts
Posted January 19, 2017 - 06:16 PM
Thats what I do too.....My LGT Fords will hold a regular car battery, so thats what they get.
#11 BigFlash OFFLINE
BigFlash
  • 231 Thanks
  • 130 posts
Posted January 19, 2017 - 07:36 PM
All of our deeres with k321s have group 26r car batterys. I'm sure they are overkill, buy you can crank for a long long time and the charging systems has no problem filling them back up.
So basically i agree with the biggest battery you can easily fit in the tractor.
#12 miller_time OFFLINE
miller_time
  • 31 Thanks
  • 46 posts
Posted January 19, 2017 - 08:41 PM
I use car batteries also. They seem to last alot longer. For some reason i only get about 2 years out if the lawn and garden batteries. I put a car battery in my jd 312 7 years ago still going strong.
Sent from my SM-G930V using Tapatalk
#13 adamjd200 ONLINE
adamjd200
  • 1,881 Thanks
  • 2,009 posts
Posted January 19, 2017 - 08:51 PM
I average 3years+/- out L&G batteries and have been happy, we run a L&G battery in my dad's CC 782 ( kt17) with no issues.
#14 framesteer OFFLINE
framesteer
  • 397 Thanks
  • 188 posts
Posted January 19, 2017 - 10:52 PM
For reference, here is a table of standard battery sizes
Attached File  Battery Size Chart a.xlsx   23.04KB   30 downloads
Edited by framesteer, January 19, 2017 - 10:53 PM.
  • nitro said thank you
#15 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted January 19, 2017 - 10:56 PM
attachicon.gifBattery Size Chart a.xlsx
That should be a sticky somewhere!
