Adding fluid to tires
12 replies to this topic
#1 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted January 18, 2017 - 03:39 PM
I have seen a number of ways to add fluid to tires on Utube, etc. Yesterday I decided to try it on my tractor (tire size is 23x8.5x12). I managed to get 5 gallon in each tire, weighed the tire and rim before and after, it increased the weight by 40 lbs. I put tubes in the tires and used  -20 degree washer fluid.
I took the center out of a valve cap (white plastic punched out from threaded end) & clamped it in a piece of clear tubing on the other end I used a fountain pump. I also put a tee and a cap inline so I could burp the air out  if needed. The ruler was to tell when it slowed down pumping.
Note, tee was not needed, when I unplugged power it would clear the air on it's own, I took the pump out of one of the wife's projects but Harbor Freight has some for less than $10.
It is a inexpensive rig and seemed to work well ( or at least better than I was expecting )
Good luck if you try it this way. Approx.  2 Hrs
Edited by grattone, January 18, 2017 - 04:16 PM.
  • Gtractor, limebuzz, speedbird and 8 others have said thanks
#2 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted January 18, 2017 - 07:53 PM
I used a garden sprayer to fill my rear tires.  It worked very well and was quick. 5 gallons per tire.
  • limebuzz, old coot, grattone and 1 other said thanks
#3 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted January 19, 2017 - 08:51 AM
When I put fluid in my tires I just broke the bead and was able to get 6 gal in each one.
  • Sawdust, old coot and grattone have said thanks
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted January 19, 2017 - 04:19 PM
TSC sells an adaptor that screws onto the nipple with a female water hose fitting. That is what I used and it did well. Hook the other end of the hose to an upside gallon jug with the bottom cut out. Gravity fed and burped plus no need to break a bead.
  • Sawdust, old coot, grattone and 1 other said thanks
#5 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted January 20, 2017 - 08:57 AM
I was in TSC a while back and didn't see anything that looked like you could hook a water hose to but did see an item that looked like it would would fit in place of the valve stem.
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted January 20, 2017 - 09:33 AM
This is the one:
http://www.tractorsu...RII0aApsx8P8HAQ
  • limebuzz and Sawdust have said thanks
#7 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted January 20, 2017 - 10:12 AM
I need to go back and look again.
#8 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted January 20, 2017 - 10:27 AM
Probably around the tire repair section!
  • twostep said thank you
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 20, 2017 - 10:42 AM
Go down the left side all the way to back, turn left, against the outside wall about 15 foot short of the corner.
  • KennyP, CRFarnsworth, Dugmf12 and 1 other said thanks
#10 WHdbJD OFFLINE
WHdbJD
  • 701 Thanks
  • 523 posts
Posted January 20, 2017 - 01:26 PM
If you click on the TSC link posted above by Twostep , you can put in your zip code and see if your
local TSC store has one in stock.
  • Sawdust said thank you
#11 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted January 20, 2017 - 02:01 PM
That's exactly where it's at.   Have you been to the local TSC?       :D       Rick
MY brother just bought one there.
Edited by CRFarnsworth, January 20, 2017 - 02:01 PM.
  • KennyP and Cat385B have said thanks
#12 BTS ONLINE
BTS
    Make Stuff Up
  • 4,634 Thanks
  • 2,609 posts
Posted January 21, 2017 - 12:02 AM
I fluid filled tires on my mobility big dipper loader (8x15 tires) and I did the tires on my Kubota L2000 (8.3X22 tires). The mobility held around 7 to 8 gallons per tire and the Kubota held around 12 gallons per tire.I used RV antifreeze, it is rated for colder temps so it uses less and saves a little $$. I used a RV antifreeze lid, pulled off the white safety part of the cap, then took the threaded part of the cap, drilled a hole in it and then pushed a valve stem in. I then removed the valve core and got a clear plastic hose that fits tight on the valve stem. I then screwed the lid on the antifreeze jug then cut the bottom of the jug out. I hung the jug upside down, attached the other end of the hose to the valve stem on the tire and filled the jug up with fluid. It runs through pretty quick, after one gallon goes in, it then bubbles out a bunch of air, then I dump in a gallon of water, the gallon of RV antifreeze, then water and so on. I always go antifreeze first, so I don't get the mixture to weak, of anything I always end up with a little more antifreeze then water.
I am needing to buy tires for my Bolens G152, I am going to fluid fill them and film every step. I am starting to make videos of all my projects and normal things I do around the farm for how to videos on YouTube.
#13 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted January 21, 2017 - 10:04 AM
Both local TSC stores say low stock so they just might be out right now.
