I brought this tractor home not long ago planning to fix it up a little to go with my 700 but a lack of time space and money right now has me putting it up for sale. I might take partial trades on a Sears 3 point or Sears Suburban 46 inch snowplow or possibly even a 14 or more HP single or twin cylinder horizontal shaft engine. This little 725 has been upgraded from the original cast iron model 19 Briggs engine to a larger model 23 cast iron Briggs ( the main reason that I picked it up because I have done the same to my 700 ),it also has a newly rebuilt starter generator. I added the correct grill,missing rear lift,correct size clutch idler pulley,and also replaced the missing rope cup on the bevel gear box. I also replaced the front tires with a matching pair.the tractor runs and drives good but needs tlc. It is a good one to fix up or restore. The deck seems to be in good shape. The rear ag tires don't go with the tractor. Instead it will come with 6-12 Goodyear turf tires.
Located west of Crawfordsville IN.47933. Asking $350
