Delco Starter/Gen. has high-pitched whine.
9 replies to this topic
#1 1965 Husky 1K OFFLINE
1965 Husky 1K
  • 11 posts
Posted June 05, 2011 - 08:59 AM
Have a delco starter/gen that has a high-pitched whine that paralells speed of engine. Charging fine. Could it be a bearing issue???? Has anyone ever run across this before??? I dont think it has been very long since it was overhauled, but I dont want to do it again if its not needed. I oiled the cups for the bearings- still noisy. I dont want to over-lubricate. Any and all suggestions appreciated.
#2 NUTNDUN OFFLINE
  • 10430 Thanks
  • 15622 posts
Posted June 05, 2011 - 09:08 AM
Have you put a multimeter on it to check to see what the voltage is that it is putting out? I am going to lean towards the bearings though. Do you happen to know if the bearings were replaced when the starter/generator was rebuilt?
#3 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 05, 2011 - 09:13 AM
I also lean toward a bearing. I'm not sure if the old lube cap type can be swapped to sealed bearing or not. But either way, it's likely a bearing.
  • 15109 Thanks
  • 15570 posts
Posted June 05, 2011 - 09:15 AM
I agree with the guys, I think it's a bearing giving you the noise.
#5 Bolens 1000 ONLINE
  • 17293 Thanks
  • 18793 posts
Posted June 05, 2011 - 08:31 PM
Sometimes the belt will also make a whining noise that gets louder with the increased RPM's
Most likely a bearing though
  • Bill56 said thank you
#6 1965 Husky 1K OFFLINE
1965 Husky 1K
  • 11 posts
Posted June 06, 2011 - 07:17 PM
I was originally leaning the same way as you all. I took the belt off and manually spun the start/gen. Nice and quiet and very smooth. I didnt care for the looks of the belt. I changed the belt and all was history!!!! It didnt sound like a belt squeal to me , but I've been proved wrong once again! (no surprize).
#7 Bolens 1000 ONLINE
  • 17293 Thanks
  • 18793 posts
Posted June 07, 2011 - 08:23 AM
Glad to hear you found the problem.
I had the same thing with my Bolens. I got a new belt and all was fine
#8 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 07, 2011 - 08:52 AM
I am happy to be wrong!
#9 NUTNDUN OFFLINE
  • 10430 Thanks
  • 15622 posts
Posted June 07, 2011 - 08:54 AM
I am glad I was wrong as well. To be honest I don't think the bearings in the starter gens go bad too often. At least you don't hear about it much anyways.
#10 Bill56 OFFLINE
  • 843 Thanks
  • 2179 posts
Posted June 07, 2011 - 09:19 PM
Glad it was a simple problem to fix.
