Workaround for wrong battery terminals?
5 replies to this topic
#1 Mustard Tiger OFFLINE
Mustard Tiger
  • 73 Thanks
  • 77 posts
Posted January 17, 2017 - 01:29 PM
The only batteries I can get around here are the L type posts.  Of course the old tractors I have are all round post connectors, and nobody around here sells the connectors for L type posts so I have to order some online and replace them.  Is there a reasonable way I can get a battery hooked up temporarily so I can still use it while I wait on shipping?  Just wrap a short length of fat copper wire around the post and connector?
#2 tater195 OFFLINE
tater195
  • 1,877 Thanks
  • 1,249 posts
Posted January 17, 2017 - 01:41 PM
they do make screw in posts. I have used them on deep cycle batteries in tractors to be able to use some free batteries we bought at work for a temporary project. I got the posts at orielly for $5
Edited by tater195, January 17, 2017 - 01:42 PM.
  • MH81, Alc and boyscout862 have said thanks
#3 OldBuzzard ONLINE
OldBuzzard
  • 6,837 Thanks
  • 4,737 posts
Posted January 17, 2017 - 03:53 PM
Open the gap on the round connector so it's wide enough to fit the post between it, then just snug it up with a nut and bolt.
  • ducky, MH81, Alc and 2 others have said thanks
#4 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,822 Thanks
  • 2,413 posts
Posted January 17, 2017 - 04:18 PM
:ditto:   That is the easiest, fastest, and cheapest way to use what you already have.
#5 tater195 OFFLINE
tater195
  • 1,877 Thanks
  • 1,249 posts
Posted January 17, 2017 - 04:29 PM
I understand the "L" post thing now, :wallbanging:  I thought it was some professional lingo for the "female" post. I cut the ends off and get the crimp on welding lead connectors. They are half the price of the same connectors in the electrical department.
Make sure you tape up the POS lead if you are using the round battery cable ends on a tab battery, especially if it is around a fuel tank. A ground out could get ugly
#6 MFDAC OFFLINE
MFDAC
  • 2,790 Thanks
  • 1,422 posts
Posted January 17, 2017 - 08:45 PM
The negative lead was a round post clamp on my MF12G since I got it. I just kept using it that way.
DAC
  • DH1, ducky, limebuzz and 1 other said thanks
