Kohler id
11 replies to this topic
#1 MH81 OFFLINE
  • 29,978 Thanks
Posted January 16, 2017 - 08:37 PM
I got a Kohler with no tag. I think it's a 241 or 301. Any idea what it might be?
#2 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted January 16, 2017 - 08:59 PM
RED  :D
  • limebuzz, MH81, KennyP and 1 other said thanks
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted January 16, 2017 - 09:41 PM
RED  :D
Aw crap... why didn't I see that coming?
#4 diesel nut ONLINE
diesel nut
  • 767 Thanks
  • 460 posts
Posted January 16, 2017 - 09:46 PM
Check the block around the pto side of the crank.  I've seen some that had the size cast into it in the recesses by the seal.                 Stewart
#5 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted January 16, 2017 - 09:52 PM
Alan....  I'm truly sorry about that. :(
By looking at the picture,,,   is that an updraft carb. ?  :D    Rick
#6 EricFromPa ONLINE
EricFromPa
  • 4,168 Thanks
  • 3,350 posts
ID tag should be up under the coil.If it's missing the block might have K301 or K241 cast into the block on the PTO side just above the crank.But that's not 100% accurate.I've had a couple K241 blocks that were factory cast as a K301 block but bored out as a K241.
Only way to know for sure is to pull the head and measure the bore.
Here's the bore sizes for k241,k301 and k321
  • MH81, Alc, Trav1s and 2 others have said thanks
#7 HANKG ONLINE
HANKG
  • 6,592 Thanks
  • 3,529 posts
Posted January 16, 2017 - 10:04 PM
Lets see, wheel horse red if its a k-301 it should be embossed on end of PTO so I'm told.
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted January 16, 2017 - 10:10 PM
Ok, have to pull some tin and stuff to get there. Thanks.
Original tag is destroyed.
The carb Is a std WHG carb
#9 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted January 17, 2017 - 03:04 AM
Number of head bolts tells you something too.
I think it's nine for a 16 horse?
#10 MH81 OFFLINE
  • 29,978 Thanks
Posted January 17, 2017 - 07:08 AM
I think It's smaller than my 16.
#11 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted January 17, 2017 - 08:16 AM
16 hp has 10 head bolts 10-12-14hp all have 9 head bolts.
  • MH81, Trav1s and Rock farmer have said thanks
#12 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,108 Thanks
  • 10,179 posts
Posted January 17, 2017 - 08:40 AM
By now, you could have had that head off, Alan.
  • limebuzz and MH81 have said thanks
