Stuck valves or scored cylinder
7 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted January 16, 2017 - 04:37 PM
Those are my choices.  I need to replace my tiller engine (5 hp, dual output shaft).  I can choose between a 4 hp tiller engine with a badly scored cylinder wall & a broken head bolt, and a 5 hp single output engine with gear reduction box with a stuck valve & two stuck lifters.  I would need to swap the crank & cam shaft if I go with the 5 hp.  Which way would you go?
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted January 16, 2017 - 04:59 PM
What is wrong with the original engine?  Is it possible to rebuild it?
#3 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted January 16, 2017 - 07:14 PM
The existing engine was making an evil noise the last time I had it out.  Sounds like it is either rod knock or lifters smashing into bent valves.  I would tear it apart but it is still on the tiller behind a door that is frozen to the ground.  Got to love freezing rain.  These two were in my other shed.
  • ducky said thank you
#4 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted January 16, 2017 - 07:34 PM
Cl for a different 5hp, a freebie, or a dirt cheap garage sale special is what I'd be in pursuit of!;)
#5 framesteer OFFLINE
framesteer
  • 436 Thanks
  • 208 posts
Posted January 16, 2017 - 10:28 PM
I'd try the 5 hp first as you have a better chance of fixing the valves compared to scored cylinder.
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 17, 2017 - 10:52 AM
  I've heard of some finding a good used block, piston, rod, and crank that the sump cover will interchange on and using it and the cam to bring it back to life. I think it was lack of foresight that came up with this design in order to have a reverse gear in that the tiller would outlast the engine and in the future no one would build replacements.
        Mike
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,982 Thanks
  • 2,476 posts
Posted January 17, 2017 - 04:39 PM
Are these B&S, or Tecumseh engines?
There's really no practical fix for a badly scored cylinder bore.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted January 17, 2017 - 09:17 PM
B&S.  The 5 hp is a 130252 0049 01.  The 4 hp is a 100292 0507 01.  I am wondering if I can oversize the 4hp bore to fit the 5 hp piston.  It is a full .065 larger.  Downside to that solution is the 5 hp piston has a stuck top ring.  It feels pinched, as if the outer rim has been hit.  It isn't stuck by carbon build up, & it is only in one spot.
