Cargo carrier for traction
33 replies to this topic
#1 4tom ONLINE
4tom
  • 155 Thanks
  • 166 posts
Posted January 12, 2017 - 09:29 PM
Added receiver hitch and cargo carrier. Will use buckets of sand to add weight for traction.
  • grnspot110, Alc, FrozenInTime and 2 others have said thanks
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,000 Thanks
  • 4,414 posts
Posted January 12, 2017 - 09:36 PM
That should work pretty good. I use mine for shows, but it helped to counter weight the blower, until the cooler was emptied.
  • KennyP, FrozenInTime, grattone and 2 others have said thanks
#3 Sawdust ONLINE
Sawdust
  • 5,667 Thanks
  • 3,374 posts
Posted January 12, 2017 - 11:13 PM
Be careful I can see you doing some wheelies without some front counter weights.
  • KennyP, FrozenInTime, Jazz and 2 others have said thanks
#4 KennyP ONLINE
  • 38,384 Thanks
  • 45,933 posts
Posted January 13, 2017 - 06:49 AM
As high as that is, it may not take to much weight to lift the front.
  • FrozenInTime said thank you
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,000 Thanks
  • 4,414 posts
Posted January 13, 2017 - 10:25 AM
When I stood on mine (230ish) (without the blower) I could get the front end off the ground. Although rated for 500 lbs, I wouldn't go over a hundred or so, unless the front was weighted. It is very useful for other things other than weight.
#6 Jazz OFFLINE
Jazz
  • 2,393 Thanks
  • 1,441 posts
Posted January 13, 2017 - 12:28 PM
I agree as far as how much weight to load.  Great idea for shows to have a cooler handy, lawn chairs and even a bbq. 500 lbs is a stretch for those things.
#7 4tom ONLINE
4tom
  • 155 Thanks
  • 166 posts
Posted January 13, 2017 - 12:43 PM
It's only rated for 300 lbs, and I don't expect to go even close to that. I'm thinking 2 buckets of sand and a scoop. It's only intended for plowing traction, but may find light duty for other uses. The plow probably adds 50+ to the front of the tractor. If I get really ambitious I might narrow the carrier to the tractor width over the summer. Probably wont happen. I stood on it when done, and bounced a little bit without lifting the plow off the ground at all.
Tom
  • Sawdust and FrozenInTime have said thanks
#8 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted January 13, 2017 - 12:50 PM
I took another route in adding weight, built a box that sets on the trailer ball and has a long rod thru the back hitch on my 7010 Simplicity. the container in the box is filled with 60 lbs. of  sand and a chain that weighs 20 lbs.  I modified a Cub Cadet blade and installed it on the tractor. I was pleased with the way it handled the 8" snow we had last week, but have ordered a set of tube's for tires so I can fill them also. Should add that piece of 4x7 tubing under the foot rest has 4 car chains in it that weights 40 lbs.
Edited by grattone, January 13, 2017 - 12:53 PM.
#9 FrozenInTime OFFLINE
FrozenInTime
  • 654 Thanks
  • 402 posts
Posted January 13, 2017 - 01:12 PM
That much weight that high and far back might damage that gt in my opinion.  If you must do that, I would not put much on and I would tie it to the very front of the carrier.  I have 200 lbs on the back of my 2370, when I remove the loader the front gets very light.  Does not take much weight to give a little extra traction.  Have you thought about wheel weights?
  • Sawdust and 4tom have said thanks
#10 4tom ONLINE
4tom
  • 155 Thanks
  • 166 posts
Posted January 13, 2017 - 04:41 PM
This just seemed more practical than wheel weights, since I can use it for other things when not plowing. It now has one bag of sand in an outdoor storage box I found on sale at Dicks for $16. The farther back I put the weight the more leverage it provides. I can always add more weight, and will have a scoop in there in case I want to spread some of the sand for more traction. Will have an extra bucket of sand available in case I need it. Will add more photos from my phone shortly. Total cost so far less than $100. and a couple hours labor (mostly re-drilling the receiver mount).
Photos are posted, last one is sideways.
Also tractor should handle the weight better than a loaded triple bag grass catcher, which probably attaches to the same mount point I attached the receiver hitch to.
Edited by 4tom, January 14, 2017 - 04:54 PM.
  • shorty and FrozenInTime have said thanks
#11 4tom ONLINE
4tom
  • 155 Thanks
  • 166 posts
Posted February 09, 2017 - 07:54 PM
First test today: inconclusive
more snow than slush, didn't pack at all
Front is definitely lighter, but not too light. Feels like balance might be good, but need a colder snow to test it.
#12 secondtry OFFLINE
secondtry
  • 1,902 Thanks
  • 1,387 posts
Posted February 10, 2017 - 01:18 AM
    I mounted a 60 plus pound back blade on my JD 112. It provides weight to counter balance the front blade. But when the front blade is down on the ground the front wheels are lightened to the point that the diagonal front blade will start to push the front of the tractor sideways with about 5" of snow. Wheel weights and loaded tires would provide traction and not have the same effect. They would also be less strain for the axle  bearings. Don
#13 4tom ONLINE
4tom
  • 155 Thanks
  • 166 posts
Posted February 12, 2017 - 09:55 PM
That's not the first reply about the axle bearings. Are they a weak point I need to worry about ? I only have about 20-30 pounds of sand on the carrier. I would think a loaded grass catcher would be heavier. I think sears sells a 50 odd pound rear weight kit for traction.
  • shorty said thank you
#14 secondtry OFFLINE
secondtry
  • 1,902 Thanks
  • 1,387 posts
Posted February 12, 2017 - 10:18 PM
   I have no particular reference to the bearings being week. Looking at the picture it looks like a lawn tractor you are dealing with. Considering the size of the axle on my craftsman LT 6000 the bearings can not be very massive. when you hang weight of the back of the tractor you effectively transfer the center of gravity back over the rear axle. Considering 400lb tractor 200lb rider plus blade and added weight the strain on the bearings is considerable.  Don
#15 John Arsenault ONLINE
John Arsenault
  • 2,586 Thanks
  • 1,213 posts
Posted February 13, 2017 - 09:23 AM
Strapping this radiator onto the back of the sears was the best idea I had all year. We have not been able to get this thing stuck so far this year.
Wish I could say that about my horse.
Today is going to be a really nasty one for us,
No more reckless abandonment, this time we go in with a plan.
