Wanted
Cub Cadet snow blade mounting bracket
4 replies to this topic
#1 Vitte30 OFFLINE
Vitte30
  • 23 Thanks
  • 23 posts
Posted January 11, 2017 - 11:14 AM
Hi guys I'm looking for a mounting bracket to fit my '61 Original. I came across this blade but I either need to build or buy a mounting bracket. From what ive gathered the bracket from 61-62 is different from 63 and up. As pictured here. Is this correct? I believe the '63 and up will still fit depending on wide/narrow version. I think mine is a narrow? Correct me if I'm wrong please. I would also like to get dominions if anyone is willing to share this information it would be greatly appreciated. Thank you
  • Traill95 said thank you
#2 diesel nut OFFLINE
diesel nut
  • 689 Thanks
  • 422 posts
Posted January 11, 2017 - 01:03 PM
To put that blade on an original you need parts 8, 9, and 10 to mount it correctly on the tractor.  The lift arm goes inside the frame instead of the outside so the lift bracket on the plow is in a different location.  The bracket for 63 and up won't fit easily due to the tractor frame on the original being unique to that tractor
#3 Vitte30 OFFLINE
Vitte30
  • 23 Thanks
  • 23 posts
Posted January 11, 2017 - 02:56 PM
Ok thank you. So you know how wide the A frame is on part 10? I may just have to build a modified bracket at this point then since I have the wrong A frame assembly. I'm paying 20 bucks for it so I can't pass it up!
#4 diesel nut OFFLINE
diesel nut
  • 689 Thanks
  • 422 posts
Posted January 11, 2017 - 04:35 PM
I believe the A frame is the same width as the one on the plow you're getting.  I'll have to see if I have one I can measure to double check.  The triangle tab it shows on #10 in the diagram is the biggest difference as it looks from the pictures I've seen to be welded on and straight and the later ones are offset and bolted on
#5 diesel nut OFFLINE
diesel nut
  • 689 Thanks
  • 422 posts
Posted January 13, 2017 - 02:24 PM
I tracked down an original blade to measure and the #10 A frame is the same width as the one you're getting.  I think you might be able to make a bracket like #21 or 23 and be able to put the lift rod on the outside of the frame.  And looking at an original and a narrow frame tractor side by side here at work if you can find #15 push frame it might go on with only minor mods.
