U joint help
14 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 10, 2017 - 09:35 PM
I am looking at u joints for a project, I think I found one made by Weasler but their chart doesn't show part numbers, anyone know how to get the part numbers, the specs are,
Cap diameter: .59"
Width, cap to cap: 1.50"
Series 02
Any help would be welcome.
#2 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 10, 2017 - 10:23 PM
Check your local implement dealers.  Most handle Weasel products.  Weasel does not sell to the public.
  • Alc and adamjd200 have said thanks
#3 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 10, 2017 - 10:58 PM
So I basically have to go to a dealer to find what I am looking thanks.
  • victor3ranger said thank you
#4 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted January 11, 2017 - 04:16 AM
That is a tiny u-joint! Good luck finding anything like that. If you can go larger do so as the parts will be much easier to find.
#5 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 11, 2017 - 05:19 AM
It appears Weasel starts with a #6 joint.  I have used those on garden tractors alot with great results.
Here are a couple of pieces of literature that may help you.
The second one has everything you need to know about PTO shafts
Attached File  NA-Universal-Joints.pdf   98.65KB   45 downloads.
Attached File  weaslerProductGuide.pdf   8.86MB   60 downloads
  • Alc, Bruce Dorsi, KennyP and 2 others have said thanks
#6 shorty ONLINE
shorty
  • 5,288 Thanks
  • 5,169 posts
Posted January 11, 2017 - 06:44 AM
Just another odd thought, call Paulb parts counter with those specs. If anyone can find it they will.
  • adamjd200 said thank you
#7 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 11, 2017 - 06:54 AM
Check here.
http://beldenunivers...niversal-joints
#8 chieffan OFFLINE
  • 9,609 Thanks
  • 6,427 posts
Posted January 11, 2017 - 07:53 AM
I would go to my local welding/ag repair shop.  They should have parts on hand to make what you need and will probably have parts down the road.  A lot of feeding and other ag equipment uses small drive shafts to operate augurs, pumps. etc.
  • Alc, adamjd200 and propane1 have said thanks
#9 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 11, 2017 - 10:34 AM
attachicon.gifNA-Universal-Joints.pdf.
The first one listed in the the first chart in the link above is what I'm looking for.
attachicon.gifweaslerProductGuide.pdf
Edited by adamjd200, January 11, 2017 - 10:35 AM.
#10 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 11, 2017 - 10:37 AM
Can't go any larger or I would.
#11 tiretrx OFFLINE
tiretrx
  • 2,230 Thanks
  • 1,217 posts
Posted January 11, 2017 - 11:46 AM
Is a flexible shaft an option, in lieu of rigid shaft and u-joint? I'm guessing the torque requirements are minimal, based on the size UJ you describe?
Edited by tiretrx, January 11, 2017 - 11:47 AM.
#12 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 11, 2017 - 06:06 PM
I am going a different route with this project, not going to modify my existing parts, just going to buy all new, thanks for everyone's help, this was what I was going to modify, just going to build a new shaft.
Edited by adamjd200, January 11, 2017 - 06:08 PM.
#13 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted January 12, 2017 - 04:11 AM
That looks like the driveshaft joints off of my Bolens snowthower? That blew apart on me when i needed it most.. a lot of hydro transmissions were driven with those little fellas.
#14 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 12, 2017 - 04:14 AM
That looks like the pin and block joint. They can be repaired too if your yokes are not damaged.  I have some description and parts info to repair those joint if you would like to go that way.  Massey used them all over there GTs.  They can be made greaseable too when you do the rebuild.
I have also replaced them with Weasler #6s if room and length were not issues.
  • Alc, KennyP and adamjd200 have said thanks
#15 adamjd200 OFFLINE
adamjd200
  • 2,020 Thanks
  • 2,149 posts
Posted January 12, 2017 - 06:53 AM
Thanks but at least one yoke is spread some at this point, one with the flange is a rusted mess, I'm just going to build a new half shaft using neapco n1000 series, I bought the replacement shaft for the other end (tractor side) which is still good. The only thing I can't find is a flange yoke with 3 holes but I could always just get one and drill new holes.
