loosing power
6 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 04, 2011 - 07:49 PM
my panzer 1107 runs great after a carb rebuild and governor work. But, kow it runs perfect when ur on a flat but looses rpm and power when goin up hill or pulling a trailor. what could be wrong. Idk if the 7hp has enough power to pull a 800 pound tractor with a 235 pound me on it. Whats wrong
#2 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted June 04, 2011 - 08:18 PM
Is the engine loosing rpms? When you say pulling your trailer is it while going uphill also? If it is could just be your float setting on the carb.
#3 MH81 OFFLINE
Posted June 04, 2011 - 08:50 PM
If you are driving on the flat and then start up hill, does the governor respond? If it does, it probably is just what Nutndun said, if not... Hopefully just gov adjustment.
#4 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted June 04, 2011 - 09:04 PM
Idk but that is alot of weight for the little 7hp to pull. You could look at the gearing off the motor also.
#5 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted June 04, 2011 - 09:34 PM
7hp is plenty if the gear ratios are right
#6 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 05, 2011 - 08:18 AM
yea it looses rpm going up hill. the float is set completly level so IDK. Im goin to try and work on it again today and see what happens
#7 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted June 05, 2011 - 08:26 AM
If the float level is set right then we can rule that out. Can you tell if the governor is kicking in when the engine starts getting a load on it?
