Snow thrower attachment help
5 replies to this topic
#1 Li_Red_Neck OFFLINE
  • 11 Thanks
  • 25 posts
Posted January 08, 2017 - 10:16 AM
Hey guys I have a Scott's S 2554 garden tractor manufactured by John Deere I purchased a snowthrower attachment for it brand-new that is correct for my machine.. I installed everything as the manual says .. I went to use it today and the augers are spinning the wrong way causing the snow to go down and not out to shoot.. does anybody know what could be the cause of this?IMG_3620.JPG IMG_3621.JPG IMG_3622.JPG
#2 Cvans ONLINE
  • 6,789 Thanks
  • 6,184 posts
Posted January 08, 2017 - 10:22 AM
That would have to be disappointing. Hope someone comes along that can help you.
#3 John Arsenault ONLINE
John Arsenault
  • 2,725 Thanks
  • 1,258 posts
Posted January 08, 2017 - 10:37 AM
The only things I can think of  is that maybe you twisted the belt on the tractor end where it connects to the engine. Look at that belt like it reins on a horse, if you reversed them pulling with your right hand would pull on the left jaw of the horse leaving the horse very confused.
The front near the blower looks correct and I am not sure how everything would line up if you reversed the belt , but it would be my first thing to look at .
#4 Cat385B ONLINE
  • 14,148 Thanks
  • 10,058 posts
Posted January 08, 2017 - 10:48 AM
Switch how the belt routes around the snowblower pulley. If the belt coming from right rear pulley on the snowblower frame goes under the big snowblower pulley currently, switch it so the left side one goes under instead. Or vise-versa.
  • MH81, boyscout862 and John Arsenault have said thanks
#5 boyscout862 ONLINE
  • 13,184 Thanks
  • 9,279 posts
Posted January 08, 2017 - 12:44 PM
I agree with both of the above. As long as everything is otherwise routed correctly, all it would take is a twist of the belt at the engine or the blower to have it rotating in the wrong or right direction. Post some clearer pics and Good Luck, Rick
Edited by boyscout862, January 08, 2017 - 12:45 PM.
#6 Li_Red_Neck OFFLINE
  • 11 Thanks
  • 25 posts
Posted January 08, 2017 - 05:56 PM
Thanks guys that's what it was I twisted the belt around and now it's working perfectly thank you for your help
  • limebuzz, MH81 and Cat385B have said thanks
