Bolens Versa Matic Lot
14 replies to this topic
#1 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 07, 2017 - 06:23 PM
I recently purchased 2 Bolens Versa Matics and some implement and am looking to get as much info as possible. One is nearly complete and original. The other has a Chinese motor on it but I have the original Briggs that was on it. I also have a few implements that came with it as well. Curious what it's all worth, the age of these machines and advice on restoration.
IMG_3410.JPG IMG_3411.JPG IMG_3422.JPG IMG_3421.JPG IMG_3412.JPG IMG_3413.JPG IMG_3414.JPG IMG_3415.JPG IMG_3416.JPG IMG_3417.JPG IMG_3418.JPG IMG_3419.JPG IMG_3420.JPG
Edited by Tdjohnson1187, January 07, 2017 - 06:47 PM.
  • Bolens 1000 and Clifford Bridgford have said thanks
#2 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted January 07, 2017 - 06:59 PM
Looks rough but mostly surface rust they would restore nicely, cant help you with a price but there are guys who collect them , if you were closer I'd like to have that sickle for my Versa-Matics
I would put yours 1958-1960
  • Tdjohnson1187 said thank you
#3 wilberj OFFLINE
wilberj
  • 5,053 Thanks
  • 5,615 posts
Posted January 07, 2017 - 07:02 PM
Welcome!
The tractor ID tag numbers will let us tell you more.
#4 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 07, 2017 - 07:06 PM
#5 boyscout862 OFFLINE
  • 13,446 Thanks
  • 9,392 posts
Posted January 07, 2017 - 08:20 PM
Welcome to GTT. Checkout our Manuals Section for info. Good Luck, Rick
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted January 07, 2017 - 09:12 PM
... Curious what it's all worth, ...
Them's fight'n words ...
  • Gtractor and Tdjohnson1187 have said thanks
#7 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 12, 2017 - 10:56 PM
Based on the serial numbers in the pictures posted above is there a reference to the year they were built? Also what Briggs engine is original to these? And 8r6 or something else? The Briggs motor on them doesn't have any serial number on it.
#8 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,948 Thanks
  • 2,462 posts
Posted January 13, 2017 - 08:08 AM
Bolens never released production dates by serial number information to the dealers back in that era.  .....Possibly, someone (WilberJ ?) may have some info gleaned from factory records.
Bolens printed info also has some inaccuracies, so not all info can be taken as gospel.
According to some Bolens paperwork, the Model 15FC tractors were produced in 1954 thru 1957.  ....For 1954-56 they were described as 2.5hp. ....For 1957 it was described as 2.75hp.
The Model 153 tractors were 1958 thru 1961 models.  .....For 1958 they were listed as 2.75hp, while from 1959 thru 1961 were described as 3hp.
Bolens paperwork shows all these tractors were equipped with B&S Model 81302 engines, but I'm doubtful.
  • Bolens 1000 and Tdjohnson1187 have said thanks
#9 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 13, 2017 - 01:26 PM
Both of these are slightly different. Different hitch set up and one has no pulley for front attachments like the sickle mower. Could one be a Power Ho or something different?
#10 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,948 Thanks
  • 2,462 posts
Posted January 13, 2017 - 05:57 PM
Based on the model numbers, both tractors are Versa-Matics, and both tractors had the same front & rear hitches.
If the hitches are different on your tractors, someone may have changed or modified parts or something is missing.
The engine pulley on the black engine appears to have been modified or replaced.
Manuals for both models are in the Bolens VersaMatic section of the Manuals forum linked here:
http://gardentractor...ens-versamatic/
Your pics don't show enough details to answer all your questions.
  • Bolens 1000 said thank you
#11 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 15, 2017 - 12:11 PM
I think a better set of pictures is need of both tractors.
  • Gtractor said thank you
#12 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 21, 2017 - 05:45 PM
So the engine that was on one of the tractors is a Briggs 81301 model. I need a new magneto and looked up the part no. On Briggs website but it is no longer in production and I can't find it anywhere. Does anyone have any suggestions with that?
Also I broke a fin on the flywheel when removing it. Will it still run ok or do I need to find a new flywheel?
Thanks for your help everyone!!
#13 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted January 21, 2017 - 05:52 PM
I have the coils instock
http://bolenspartsan...-b-and-s-clone/
I would think your ok on the flywheel missing a fin , but there are several on ebay for sale new if needed
http://www.ebay.com/...295936&_sacat=0
#14 Tdjohnson1187 OFFLINE
Tdjohnson1187
  • 2 Thanks
  • 6 posts
Posted January 25, 2017 - 08:16 PM
I'm looking for information on how to remove the blade from the front of the Versa Matics pictured above. I can't find the manual in the manuals section. How do you go about removing it. Does the knob in the middle have something to do with it? Sorry if that's a noob question but I figure it's always easier to ask an expert.
#15 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted January 25, 2017 - 09:39 PM
The hand wheel on the tractor needs to be loosened so your snap hitch can release it, once you do that tilt the handle bars upward and the hitch should come undone with minimal effort
  • Bruce Dorsi and Tdjohnson1187 have said thanks
