* * * * * 1 votes
Beaver riding tractor
tractor beaver
20 replies to this topic
#1 BigF30 OFFLINE
BigF30
  • 56 Thanks
  • 21 posts
Posted January 04, 2017 - 05:39 PM
I cant seem to find a form for beaver tractors so I figured I'd post here since I just picked one up today with a dirt plow and disk. Is there a way you can date them? The serial number on the brass tag says 4470-3825 but I cant seem to find a lot on them. I know mine has the Wisconsin AKN engine and also the black ball joystick on it.
Thanks!
Edited by BigF30, January 04, 2017 - 05:45 PM.
  • rustyoldjunk, hamman, KennyP and 4 others have said thanks
#2 drbish OFFLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted January 04, 2017 - 06:29 PM
The best site for want you are looking for
http://beavertractor.com/history.html
  • DH1, Alc, Bruce Dorsi and 2 others have said thanks
#3 drbish OFFLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted January 04, 2017 - 06:41 PM
This is my post ,Sadly it is one that I sold that I wish I had not
http://gardentractor...snow-pic-heavy/
  • KennyP and BigF30 have said thanks
#4 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted January 04, 2017 - 06:48 PM
Yours was made in 1953 according to the chart on the Behave tractor websight. You can also look up the engine serial number online to find out what year the engine was built. Are you planning on restoring it? I recently picked up a 1951 Beaver which is basically the same thing. I'm in the process of restoring mine, so if you have any questions, I may be able to help. HAPCO has the stencil or decal available for the belt guard, and they also sell reproduction reverse discs if yours is worn. Just give Brandon a shout and let him know what you need. Congrats on the purchase of the Beaver tractor! They make great restoration projects and are very simple to work on.
  • BigF30 said thank you
#5 BigF30 OFFLINE
BigF30
  • 56 Thanks
  • 21 posts
Posted January 04, 2017 - 07:03 PM
That's a nice tractor you had
I dated the engine at 1951 from the Wisconsin site so the engine might have sat around for a while before they used it. I also might have paid a little to much for the tractor at $250 but it's one of those things me and my old man have sought for, yet were never able to find it till now. A few Mennonite buddies of mine are always out looking for odd tractors to sell from their sandblasting business so I normally get first looks. I've ended up buying a large handful of odd things from them over the years. My dad and I are going to get the tractor running sometime this month first, then we'll take it apart for sandblasting at the guys I bought the tractor from next year.  This tractor was originally used for just use in a garden with the plow...someone willed the one tire with concrete (don't ask me how). Could you send me a photo of what those reverse discs look like?
Edited by BigF30, January 04, 2017 - 07:05 PM.
#6 BigF30 OFFLINE
BigF30
  • 56 Thanks
  • 21 posts
Posted January 04, 2017 - 07:09 PM
That is a nice tractor you had and I hope ours looks half as nice when its done. I honestly don't know If I'll ever get used to the steering configuration, I just feel kind of clumsy on it. I'm guessing the ground speed on these are fairly slow?
#7 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted January 04, 2017 - 07:46 PM
Cool tractor! Hope it starts easily for you!
#8 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted January 04, 2017 - 07:53 PM
BigF30. Here is a pic of the reverse disc. It engages directly into a pulley groove to make the tractor go into reverse when you push down on the pedal with your heel. I think 250.00 is a great price considering what you have there. They are very well made, and a great piece of garden tractor history. Search Baird Beaver tractor on youtube and you will see some videos people have posted. This will give you an idea of the top speed. The Wisconsin on my Beaver is dated 1950 and my tractor was built in '51, so engines could have an earlier date than the build date of the tractor. For one thing, these Wisconsin engines are not cheap to rebuild. One thing that you must do is remove the pan from the bottom of the engine. Clean the oil pump and oil pump pick up screen. Check for wear and slop between the connecting rod and crankshaft journal. If the engine tosses the rod, it will most likely put a large hole in the block. I know of two AKN's that this happened to.
#9 BigF30 OFFLINE
BigF30
  • 56 Thanks
  • 21 posts
Posted January 04, 2017 - 08:08 PM
Thanks! Around here parts for these engines are rather easy to find thanks to most of the local farmers still using them. I rebuilt a Wisconsin THD a few years ago (oil pump blew a cap on the oil pump). New rings, a piston, rebuilt the oil pump, exc. It ran me around $150 plus the $75 I gave for the motor and box it was parted in. :wallbanging:  I'll pull the motor on the beaver and clean it up a bit to see how she looks. Are there any other weak points I should look for on the tractor?
Edited by BigF30, January 04, 2017 - 08:10 PM.
  • classic and geissenkid have said thanks
#10 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted January 04, 2017 - 08:22 PM
I forgot the pic of the disc, here it is. Pop off your rear hubs and check the pawls, since these can wear badly. There may be locks installed inside the hubs that lock the rear end. Without them, you basically have an open differential that creates less stress on the rear axle. There is a chain in the transaxle, and you can adjust the tension by loosening the bolts on the pinion shaft assembly under the belt guard. To adjust the drive belt tension, just slide the engine forward. My pinion shaft and bushings were badly worn, so I bought new bushings and made up a new shaft assembly. The front spindles may be worn on your tractor, so just disassemble the front end and check things out. Here is my new pinion shaft assembly.
#11 Jazz OFFLINE
Jazz
  • 2,707 Thanks
  • 1,566 posts
Posted January 05, 2017 - 08:12 AM
Now I want a Beaver! Would be a great gift for the wife. What a conversation starter that would be!
Edited by Jazz, January 05, 2017 - 08:14 AM.
  • BowDown and BigF30 have said thanks
#12 BigF30 OFFLINE
BigF30
  • 56 Thanks
  • 21 posts
Posted January 13, 2017 - 10:20 AM
I just found out that we don't have matching rims on the front of the tractor, they seem to be split rims with a number of bolts holding it together. Just wondering if anyone had any extra floating around?
Thanks!
#13 classic ONLINE
classic
  • 5,695 Thanks
  • 2,386 posts
Posted January 13, 2017 - 01:53 PM
Here is the only one that I know of, but the hub is keyed. You would have to install bronze bushings to use it. These split rims are fairly hard to find.
www.ebay.com/itm/VINTAGE-PLANET-JUNIOR-Walk-Behind-Garden-Tractor-TIRE-WHEEL-RIM-Waterbury-/172478800393?hash=item282889a209:g:7cIAAOSwcvdXOjSl
#14 jabelman ONLINE
jabelman
  • 2,329 Thanks
  • 1,645 posts
Posted January 13, 2017 - 09:44 PM
yeah they are tough and usually expensive to find, the sears david bradley series used a similar front rim. sometimes you get lucky
  • classic said thank you
#15 Budman OFFLINE
Budman
  • 5 Thanks
  • 3 posts
Posted February 21, 2017 - 01:04 AM
Hi all,
Just picked up a 1955 Beaver. It was my dads, and last time I saw it was 45 years ago. I looked on CG and knew right away this was the one we had when I was a child. 100.00 bucks and now to get to work. Front wheel seized, rear tires shredded. Really just want to get her rolling again to be able to work on her. Love to put temp rims and tires on it for now. Anyone know the rear bolt pattern size?
Thanks and will post pics once I learn how.
Bud
Also tagged with one or more of these keywords: tractor, beaver
