Portable Hydraulic Test Stand
68 replies to this topic
#61 Alc OFFLINE
  • 6,885 Thanks
  • 7,461 posts
Posted January 19, 2017 - 06:29 AM
This might be of help.
http://harrisburg.cr...5926815306.html
If that pressure gauge isn't broken it would be a steal for someone . We have them at work and before we got the digitals that's all we used . Its nice because you can get accurate readings with just one set-up . some how it doesn't damage the low pressure gauges as it goes to it's limit , just start reading on the next highest , then the third
  • KennyP and sacsr have said thanks
#62 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted January 19, 2017 - 06:37 AM
Nice! Alc sent me a simpler version. And a few other goodies!
  • sacsr said thank you
#63 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted January 19, 2017 - 08:46 AM
I'll hook up the other Char-Lynn motor today and test it. Maybe a video of it running. Not sure if they would speed up with larger pump and bigger hoses (thus more volume and pressure). Trying to figure out a use for them. If they both work well on this pump, I may start a thread on them looking for uses.
  • Alc and EricR have said thanks
#64 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,689 Thanks
  • 2,865 posts
Posted January 19, 2017 - 12:27 PM
Could one of the motors be used as a pump?
#65 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted January 19, 2017 - 02:22 PM
Don't thinks so. They don't turn over by hand, had to use channel locks to make sure they weren't stuck. Here's the #'s off the one motor.
               07 5
101 1002 007
And here's the #'s on the valve. HYSPECO 8-72. It just looks like a high pressure cut off inside.
I did some snooping and found the motors. They are an 'H Series', 4.5 cubic inch per revolution. Maybe someone can read these charts for me. The first one has a RED dot next to the 1002. that is what is on the tag.
  • 29 Chev said thank you
#66 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 19, 2017 - 03:42 PM
Kenny I got those pumps out yesterday. Here is a tracking # for you.
Attached File  Tracking #s for Kenny.pdf   620.83KB   41 downloads
#67 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted January 19, 2017 - 05:38 PM
attachicon.gifTracking #s for Kenny.pdf
Want some of that shipping back? I'll help out with it!
For anyone interested, I uploaded a manual on the Char-Lynn motors. It is here. The ones I have are the  'H Series' and they start on page 55 of the manual.
  • Alc, TomLGT195 and 29 Chev have said thanks
#68 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 19, 2017 - 08:40 PM
Kenny
First let see if they will work for you.
#69 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted January 20, 2017 - 04:29 AM
I was going to try out the other motor yesterday, but the carb float decided it wanted to sink. Took it apart and it has a hole. Someone put some kind of glue substance over it and the gas ate it. Got it propped up right and put a 300 watt halogen lamp shining on it to get the gas out. Worked pretty good. Then I got to thinking. I had another float, but where. Finally found it. I'll put it in today and fix this one later.
  • ducky and Alc have said thanks
